Atwood Stovetop in my ATC Bobcat not working.
#1
Posted 06 September 2020 - 04:28 PM
I have had similar problems with BBQ’s and after doing some research found a solution to reset the regulator by unhooking the propane and letting it rest for a few minutes and then after hooking it back up slowly opening the valve. Unfortunately this isn’t working. I’ve read through some posts offering similar solutions. One interesting fact is my fridge and heater are still working so it seems as if the main regulator is working ok. I took the stove top cover off and it seems as if the stove has its own smaller regulator. I’m a little worried about digging into the stove regulator here in the field because if it doesn’t go well I won’t be able to isolate the stove top from the fridge and furnace.
Anybody have a fix idea?
Many thanks!!
#2
Posted 06 September 2020 - 05:46 PM
#3
Posted 06 September 2020 - 07:23 PM
Glad you were able to work this out. Anytime we've had propane pressure problems, we've done as you did - turn off the gas at the tank, remove the line to the regulator, wait a bit, and reinstall. Open the gas valve slowly. We have not had any real issues at elevation.
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
#4
Posted 06 September 2020 - 07:53 PM
I've read that opening the tank valve too fast can cause problems.
I always open the valve slowly.Never have had any problems.
Great it got worked out.
