Hello to all here, first post so be gentle.
I’m in a bit of a time crunch and don’t have much time to research so I will ask a question that I suspect I could dig up with some searching but will cut to the chase.
I’m about to get an Alaskan camper, an 8’ or 8.5 cab over. But I need a truck for it. What I would like is an F-350 extra cab 4x4. My problem is finding one I can afford and not a crew cab (it’s like 30 to one crew vs. extra). I’m looking at older 7.3 diesel...OBS and SD’s.
My problem is that their are a LOT more F250 extra cab’s with 7.3’s to chose from than F350’s. An Alaskan Camper 8’ wet and loaded with food and crap will about max out an F350 payload... can I use an F250?
I realize that F250s are the same truck as F350’s except for the springs, and after upgrading the springs it is eventually the same truck with the same weight capacity.
The only thing that will be different is what the GVWR sticker says on the door.
So at least buy my understanding in terms of safety, feel, ride and capability there should be no difference between the upgraded F250 and F350.... Anyone disagree here?
So the only thing I’m risking is getting sighted for being over weight, which is unlikely at best in the lower 48 and possible in Canada. I might get a fine if I’m on my way from the states to Alaska and bay a fine.
The Alaskan camper 8’, wet with lots of crap for an extended trip I’m guessing will come in at 3000lbs or so, maybe a a couple hundred more.
So does anyone see an issue with this logic? Still looking for a f350 but if I can’t find what I’m looking for, get an F250, upgrade the springs and call it good knowing I could get dinged but it’s unlikely.
Thoughts?
