CFX3 55IM
12 replies to this topic
#11 Outnabout
Outnabout
  • 280 posts
Posted 23 November 2020 - 04:15 AM
Checking back in... Looking at rated amperage is not correct for actual power draw. That is way too high for a compressor fridge.
Found this table below, which would make much more sense.... Still not very clear on what wattage it pulls when running. I would assume ~50W, or 4amp @ 12.5V.... below table would be if it runs at 1/4 hr on the hour (~1 ah/h).
dometic-cfx3-fridge-freezer-technical-de
Sounds reasonable. Seems to be in the ballpark with other similar fridges.
#12 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,948 posts
  • LocationCalgary, Alberta
Posted 24 November 2020 - 03:16 AM
I have a 130L Truckfridge that also runs of an Indel-B compressor.  The above data says 1.81AH/hr.  On a given 70*F day, 10 hrs of running would be lots.  That's 18AH.  Which is about what ours uses, and that's with two additional fans (one inside the fridge, the other on the compressor coils).
  • 1
#13 Outnabout
Outnabout
  • 280 posts
Posted 24 November 2020 - 05:08 AM
Thanks for the info. I think the take away here is to remember the fridge is not running 24/7. It seems that18ah a day should not, on a sunny day, be to hard to overcome.
