My 2014 Alaskan CO has window screens that seem to be riveted into the window frame, making it very hard to clean half of the window. Has anyone found away to get the screens off the windows so you can clean the windows. Some of the windows have gotten pretty gunky and cleaning them would solve a marital problem. Thanks for any help.
Alaskan Window screen removal
#1
Posted 11 December 2020 - 08:22 AM
#2
Posted 14 December 2020 - 11:34 PM
My 2016 is the same way. Not sure how to do it other than maybe spray from the inside to the outside? And then scrub it. My 2020 has screens that slide and I think they can be removed more easily. Seems like a bit better of a design.
#3
Posted 22 December 2020 - 06:24 PM
Have you checked the manuals?
Maybe call the factory?
Maybe unscrew a stop that prevents sliding that gunky panel away from the screen for cleaning?
1988 Ford F-250 HD Lariat 4x4 8 Ft. bed
1976 Alaskan 8 Ft. CO camper
#4
Posted 31 December 2020 - 01:33 AM
According the guys at the Alaskan factory there is no way to remove the screens from the windows. I was hoping someone would have a new way of getting the screens off. Not a great design. If I figure out how to do it I will post it here.
#5
Posted 31 December 2020 - 03:04 AM
Have you looked at using double sided or magnetic window washer? It may be a way you can still clean the window.
2017 Toyota Tacoma with 2000 FWC Eagle
"The nut behind the wheel is the most important one. Don't forget to snug yourself up every once in a while." John D & ri-f
#6
Posted 04 January 2021 - 01:15 AM
