Propane Capacity?
11 replies to this topic
#1 eyemgh
eyemgh
  • 312 posts
Posted 14 December 2020 - 12:28 AM
My Raven shell has two tweener propane cylinders (smaller than 20 lb classic grill tank and larger than the 5 lb-er). I *think* they're 10 pound Manchester cylinders. They are stamped with 14.4 Tare Weight. I weighed them full and they come up with just about 10 pounds more than the tare weight, 24.5.
I developed a system based on those "knowns" where I weigh the cylinder with a luggage scale to make sure I don't cut it too close.
I "ran out" today at lunch. The system cut out and wouldn't restart no matter what temp I raised it to. I shut it off and then turned it back on, but it only ran for a bit because it wouldn't light.
I pulled the cylinder to confirm my assumptions, but it still weighed a little over 18 lbs. I replaced that cylinder with a full one and it ran just fine.
I'm trying to figure this out. Is 18ish pounds the real empty weight and not the TW stamped on the cylinder or is the system configured so that it will only run a tank so low? Any insight would be greatly appreciated.
Edited by eyemgh, 14 December 2020 - 12:28 AM.
#2 JaSAn
JaSAn
    Grumpy Old Man
  • 1,105 posts
  • LocationMinnesota
Posted 14 December 2020 - 12:54 AM
What was the ambient temperature?
At below 20ºF I cannot get a 20# tank to fully empty.  The small tanks just can't maintain pressure at lower temperatures.
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#3 PaulT
PaulT
    Need gumbo
  • 2,612 posts
  • LocationHillsboro, Oregon
Posted 14 December 2020 - 01:00 AM
Search for "fill propane tank percent" and you will learn that there is an 80% fill maximum.  Therefore your 10 lb tank will contain a useful 8 lb. of propane.
Something to keep in mind when estimating how long that "full" tank will last at the appliance's burn rate.
#4 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,589 posts
  • LocationNortheast Oregon
Posted 14 December 2020 - 02:12 AM
Turn the tank valve off, turn appliances off, wait 5-10 minutes, then turn tank valve back on slowly.  There is an excess flow check valve that might need resetting.
  • 2
I am haunted by waters
#5 XJINTX
XJINTX
  • 552 posts
  • LocationEddy, TX
Posted 14 December 2020 - 12:56 PM
YES, try this :)
#6 eyemgh
eyemgh
  • 312 posts
Posted 14 December 2020 - 10:52 PM
I'll give this a try. I do tend to fling the valve open as quickly as I can.
I don't think it was the cold. It was 40 F at the worst.
The interesting thing is that it worked fine for about 20 minutes.
#7 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,338 posts
  • LocationSierra Nevada Range
Posted 14 December 2020 - 11:18 PM
After turning off the tank, I also disconnect the regulator supply line. I wait a short while and then reconnect and open the valve slowly. In these modern times I think of it as a system reboot.
#8 eyemgh
eyemgh
  • 312 posts
Posted 15 December 2020 - 08:03 PM
Thanks! I'll switch back and give it a try.
Also, this happened in the middle of the night once. I thought I was out, but I bet I wasn't. Any way to proactively prevent that?
#9 AWG_Pics
AWG_Pics
    Into the Great Empty
  • 1,197 posts
  • LocationOregon
Posted 15 December 2020 - 08:53 PM
After inexplicably not getting propane to flow to my external cooking stove I had to learn the hard way to give an extra firm twist to tighten the regulator hose to the tank. No problem since I started doing that. Lots of intermittent problems before learning that lesson.
lived for several years each in Montana, Utah, Idaho, Texas, Washington, Oregon.
2019 Tundra, Hawk.
https://www.flickr.c...hotos/awg_pics/
#10 eyemgh
eyemgh
  • 312 posts
Posted 15 December 2020 - 10:32 PM
One extra firm twist coming up!
