In the photo above:
Top left with two LED glowing on left side is the Bogart SC-2030 PWM charge controller programmed for LiFePO4 batteries.
Immediately to its right is the shunt for the RV-2030 battery monitor mounted on surface of the cabinet to the left of the cabinet door but not seen..
To the right of shunt is the tie point for the ground wires. Below that is a tie point for the solar panel ground wires to the SC-2030.
Continuing to the right is a 50 amp circuit breaker enabling me to disconnect the solar panels when working on the electrical.
Above the circuit breaker is the original Battery Isolator still mounted but disconnected from the truck alternator. Above the Isolator is the IOTA DLS-30 charger/power supply. The IQ4 module is screwed to the ceiling of the battery compartment.
Attached to the battery lug between the batteries is an MRBF Terminal Fuse Block I like them because you cannot get any closer to the terminal with any other fuse and it puts the wire lugs up top and the wires flat compared to others.
Things could be much neater and straighter if I were left handed or young and flexible so I could more easily operate tools in that tight space. I pulled the two factory AGM group 24 batteries and the GC2's fit right in after I removed the 1/2" square wooden space holder in the forward bottom of the compartment at the foot of the rightmost battery. Because the GC2 batteries are taller than the AGMs, the left most GC2 was getting a little close to some wires and bolts in the top left side of the compartment.
They are shoe-horned in there but they fit and weigh half as much as the AGM batteries they replaced.
