Hawk Victron MPPT
5 replies to this topic
#1 BrianG
BrianG
  • 196 posts
  • LocationNorthern Nevada
Posted 14 January 2021 - 06:34 AM
Hi,
I’ll be upgrading my Zamp 30a PWM solar charger to the Victron Smart 100/30 MPPT. The Victron is a much different size unit, I was wondering where folks are locating it. The Victron BMV Smart 712 will probably go in the Zamp cabinet hole with a cover plate.
Thanks
2018 Ram 3500 Mega Cab 4x4 Diesel, 2015 Hawk Silver Spur Exterior, Front Dinette
#2 Charlie
Charlie
  • 96 posts
  • LocationSugarloaf, Colorado
Posted 14 January 2021 - 02:29 PM
I used a Victron MPPT 100/20 and a BMV. I mounted the unit in the battery compartment, and the displays in the FWC provided cutout. See
https://www.wanderth...oller/?p=217016
#3 Bwht4x4
Bwht4x4
  • 427 posts
  • LocationMorro Bay
Posted 14 January 2021 - 06:26 PM
Mine's in the battery compartment too.
N6DVg3ZqMxpRFbL94uOpbuVUtg08__KumXAQ0kAq
2018 Dodge Ram 2500 Quad Cab, 4WD, CTD paired with a 2013 FWC Hawk
#4 Jack
Jack
  • 407 posts
  • LocationPortland OR
Posted 14 January 2021 - 07:01 PM
On our 2015 Fleet front dinette there is no room in the battery compartment. I mounted it behind the kitchen cabinet front panel. See https://www.wanderth...-2015-fleet-fd/
 for photo. Has worked out very well. With Bluetooth, there is no need be able to see the MPPT.
It is well worth connectorizing all of the wiring to the front panel. It takes almost as much time to disconnect and re-wire the panel as it does to add connectors. Connectorizing eliminates re-wiring errors and if you have to go back in, the next time you need to get behind it is fast and a lot easier. FWC should do this - the $30 in connectors would cut a lot more than that off of labor.
2015 Fleet on 2019 Ranger
#5 Jon R
Jon R
  • 925 posts
  • LocationWashington State
Posted 15 January 2021 - 05:19 AM
Jack - could you elaborate on where you have installed connectors?
Jon R
2021 GMC 3500HD CC LB SRW Gas
#6 CatButt
CatButt
  • PipPip
  • 23 posts
  • LocationSo Cal
Posted 15 January 2021 - 05:39 AM
I put mine in the large cabinet under the sink...on the right side face...https://photos.app.g...6br82PynDKBCCTA
