pop up truck camper tires, 6 ply, 8 ply or 10
tires
9 replies to this topic
#1 robcc
robcc
  • 57 posts
  • LocationBayfield Colorado
Posted 02 February 2021 - 02:35 AM
We just ordered our pup camper from the manufacturer for our Nissan 4wd Frontier. They said for our camper (at 1,100 lb dry payload)  a 6 ply tire D-rated tire is sufficient. A lot of people are recommending a 10- ply E-rated tire. Unfortunately, we currently have two sets of 4 ply B rated 4 ply tires (the Cooper Discoverer AT3 for summer and Blizzaks for winter) 265/70/R16. I guess we'll have to sell the 4 ply Blizzaks which are almost new.
Any suggestions on a single tire for all season that would be at least 8 ply/LT. Is it worth spending the extra money on an E-rated 10 ply tire for 1100 -1300 lbs payload capacity?
Edited by robcc, 02 February 2021 - 02:46 AM.
#2 Hoopy
Hoopy
  • 84 posts
  • Locationsouthern Wa
Posted 02 February 2021 - 02:46 AM
We just ordered our pup camper from the manufacturer. They said for our camper (at 1,100 lb dry payload)  a 6 ply tire D-rated tire is sufficient. A lot of people are recommending a 10- ply E-rated tire. Unfortunately, we currently have two sets of 4 ply B rated 4 ply tires (the Cooper Discoverer AT3 for summer and Blizzaks for winter) 265/70/R16. I guess we'll have to sell the 4 ply Blizzaks.
hi,
     I went with 10 ply I want the safety  don't want a blow out of the sidewall  and i want the abilty to know they will carry what i load.  Look on your driver door at the label which tells  you how much each axle and total wt. of rig.    hoopy
#3 veryactivelife
veryactivelife
  • 188 posts
  • LocationMaryland
Posted 02 February 2021 - 01:40 PM
If you plan to be going off pavement I would recommend E rated tires for the extra protection against cuts and punctures. Look at the tire and rim tables and see what the load capacity is for your tire size at different PSI.
https://www.toyotire...es_20200723.pdf
If you’re going off pavement you’ll probably be airing down. Also consider that off pavement the truck will be bouncing around so the effective weight will be more than the weight at the scales.
For snow get an all terrain tire (AT) with the Three Peak Mountain Snowflake rating (3PMSF).
I’ve had good luck with B F Goodrich KO2 tires, on my second set, but there are other favorites out there.
Dean
Dean and Mary
2015 RAM 2500 Cummins with 2015 Four Wheel Campers Hawk flatbed
VeryActiveLife on Facebook, instagram & YouTube
#4 Beach
Beach
  • 866 posts
Posted 02 February 2021 - 03:23 PM
I am happy with Cooper ATPs(Es) but there are lots of other very good choices out there. Besides the above mentioned pluses to an E rated tire, you'll find a much bigger selection(sizes and brands) of E rated tires vs D rated. That could also translate into being easier to find a replacement tire if the need should arise while out on the road.
#5 rubberlegs
rubberlegs
    curmudgeon
  • 563 posts
  • LocationEverett, WA
Posted 02 February 2021 - 03:28 PM
What’s the price difference?
Tacoma/Fleet 2018.
#6 smlobx
smlobx
    Lost again
  • 1,529 posts
  • LocationNorth Carolina
Posted 02 February 2021 - 06:07 PM
You get what you pay for. All things being equal the E rated tire will cost more that a similar C or D rated tire. They will usually weigh more as well.
Edited by smlobx, 02 February 2021 - 06:07 PM.
Eddie
KO4CPL
#7 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,948 posts
  • LocationCalgary, Alberta
Posted 02 February 2021 - 10:26 PM
If you are using Blizzaks now, you will not be happy with all season tires, even those with snowflake ratings.  Blizzaks come in E load rating too.
#8 AWG_Pics
AWG_Pics
    Into the Great Empty
  • 1,194 posts
  • LocationOregon
Posted 03 February 2021 - 01:50 AM
We have the continental terrain contact E rated tires. They are good on the highway and good in the back country, including loose sand.
lived for several years each in Montana, Utah, Idaho, Texas, Washington, Oregon.
2019 Tundra, Hawk.
https://www.flickr.c...hotos/awg_pics/
#9 Smokecreek1
Smokecreek1
    Smokecreek1
  • 2,762 posts
  • LocationNE Calif/NW Nev
Posted 04 February 2021 - 12:28 AM
Yep, another 10 ply E rated M/S here. I always use Big O tires like my Dad did , but lot's of choices to pick from B)!
Smoke
Smokecreek1:99F1504x4with05Granby
#10 BBZ
BBZ
  • 666 posts
  • LocationGolden, CO
Posted 04 February 2021 - 05:28 PM
E rated tires only end up being about $10 more per tire in my experience, well worth the piece of mind..
I stick to the BFG AT KO2 after using the Cooper Discoverer AT3, I find it to be just as quiet, but way better in the snow and offroad..
2023 F-150 Scab HDPP + 2013 Grandby Shell +
https://www.wanderth...ect-90s-granby/
Also tagged with one or more of these keywords: tires
