Diesel Furnace for FWC Eagle
Furnace Diesel
20 replies to this topic
#1 Desert Tortoise
Desert Tortoise
  • PipPip
  • 16 posts
  • LocationWatsonville, CA
Posted 31 March 2021 - 03:36 AM
I am  looking for a replacement furnace for my Atwood, something that will fit into the same space.
I love the Atwood but it is unreliable and repeated attempts to repair have me looking for a replacement.
I've researched several and am looking closely at Diesel Furnaces. A friend has a $150. Chinese one
that seems to work well.
Comments on these would be much appreciated.
thank you!
#2 PaulT
PaulT
    Need gumbo
  • 2,582 posts
  • LocationHillsboro, Oregon
Posted 31 March 2021 - 04:43 AM
I have no personal experience with the Chinese diesel heaters but I have been reading about them. The only caveat I have read about for an interior installation is the ticking of the fuel pump. Outside, it may not be an issue but it is worth consideration if you are a light sleeper on a cold night.
#3 SkyP
SkyP
  • 112 posts
  • LocationSouth Carolina
Posted 31 March 2021 - 09:32 AM
I've used Webasto and Espar heaters in my Transit vans.
The fuel pumps can be quite loud and are tough to silence- if that is even possible.
The fuel pumps are typically mounted outside near the fuel source- still loud- can't imagine one inside.
Personally I am unwilling to trust a $150 heater with my life, hence the Webasto and Espars.
20 F150 4x4 18 ATC Panther
96 F350 4x4  99 FWC Grandby Shell (sold)
15 Aliner Scout
18 Camplite 16TBS
#4 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,277 posts
  • LocationNortheast Oregon
Posted 31 March 2021 - 02:17 PM
Wallas diesel heaters are very expensive, but reportedly a low current draw.  We used a Wallas cooktop/heater in our boat.
Under the rocks are the words
Tu Ne Cede Malis
#5 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,012 posts
  • LocationSierra Nevada Range
Posted 31 March 2021 - 02:23 PM
Previously on Wander the West -
Chinese Diesel Heaters
#6 Hoopy
Hoopy
  • 84 posts
  • Locationsouthern Wa
Posted 31 March 2021 - 02:54 PM
I have installed a diesel heater in our flatbed hawk.  I have had both forced air propane and now a diesel heater.  We use the  FWC all winter skiing and traveling and am very satisfied.  I put a mid range priced heater in and carry a few  spare parts and  never have replaced parts yet.  The fuel pump is a noisy ticking sound,,,I  installed it outside under the flatbed itself and i can hear it if listen hard and its not a bother to me.  I like to hear it I use that as a assement tool while its operating.  The air intake and exaust is outside and  I clean it regularly and carry a spare air intake filter I built a metal shroud around the filter with plenty of space around it.  there is so much sloppy wet snow and sand and glop that undercoats the rig on winter trips.
     One struggle we all have is space to put things in our campers and in a flatbed  felt like I had lots of room to install one (after four peeps and a dog in the winter in a fleet slide in....boys refused to sleep in a tent!!).  I caution you if you decide to  install one give yourself room to do maintanence and repair work.  The forced air propane you can pop the plate off outside to get at it( sailswitch and reset butten).  I think you would be hard pressed to pop the top off the case and to work on it in the space of the old furnace.  I thought hard about mounting it either inside or outside and opted for inside.  I think outside is a viable option as well .
    I run the heater on low and like the constant heat and very minimal power use.   cheers hoopy
#7 Your Mileage May Vary
  • 59 posts
  • LocationCanada
Posted 31 March 2021 - 03:12 PM
A few thoughts »
I plan to install a Webasto heater in a ATC slide-in type camper later this year.
I'm not willing to trust the knockoff versions. The ones I have seen are cheaply made.
Webasto and Espar are spendy but have been used extensively in the trucking, farming, mining, and other industries for many years. That brings with it a level of reassurance and comfort. Life is too short to worry about the heater every time I turns on.
Webasto make a gasoline version of the same heater (I don't know if Espar do) that I plan to install. This will mean I won't need to find or carry propane as I travel long distances across borders. Gasoline is the most common fuel, and available everywhere in the world.
Robert VE9CDN » 2023 Ford Ranger FX4 with ATC Bobcat
Goal is to travel overland as slowly as possible, as far as possible, as long as possible.
AdventureTrend.com
#8 craig333
craig333
    Riley's Human
  • 7,898 posts
  • LocationSacramento
Posted 31 March 2021 - 04:09 PM
Kids didn't want to sleep in a tent? I never wanted to sleep inside with my parents unless the weather forced me to.
#9 Desert Tortoise
Desert Tortoise
  • PipPip
  • 16 posts
Posted 31 March 2021 - 06:34 PM
List,
Thank you for your responses, and future ones.
Space is a premium, hence my desire to find something to fit in the same space.
The new Atwood models will not fit my 20 year old Eagle.
I'm OK with price points up to about the $1000 range.
I would actually prefer propane since I already have that fuel on board,
electrical draw is a concern, but even the 4.5 amp Atwood I'm usually able to handle
with my solar and Lithium set up.
Almost all my camping is winter, it's becoming increasingly difficult to find quiet solitude with
OHVs everywhere.
#10 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,704 posts
  • LocationCalgary, Alberta
Posted 31 March 2021 - 07:57 PM
Considered getting a Propex?  I've installed two, and they are super reliable.  Not as quiet as a Wave or diesel heater though.  Can be made to fit into small spaces though!
Also tagged with one or more of these keywords: Furnace, Diesel
