sold! Thanks!
$12000. 2005 Four Wheel Camper Grandby model. Located in the Grass Valley area of California. In great condition and ready to camp. This is one of their larger campers and is very comfortable, with lots of storage space for one of these rigs. Large water and propane tanks along with upgraded electrical make for easy longer term boondocking. Several updates and upgrades made. This was on a Ford F-250, which I believe has the tallest cab height, so it should fit over any cab without problem. I ran this on a short bed (6.5’) and it worked great.
200 watt solar panel with Victron smart solar controller
100ah lithium LiFePO battery with built in bms
Stock Iota DLS converter has the lithium smart controller installed
MaxxFan roof fan with thermostat control
Side dinette conversion with new cabinets, converts to a bed space
Lagun table mount
Ventilated under mattress (ikea hack), with double size foam mattress
Reinforced camper tie down points with custom stainless plates inside and out and forged eyes. Forged turnbuckles.
Underside resealed and repainted with marine grade materials.
Exterior gas lift struts
Roof was redone/reskinned by ATC approximately five years ago
20 gallon fresh water tank and power water pump. Updated larger faucet
5 gallon propane tank
Double burner stainless stove
Fiamma side awning
Norcold 3-way fridge. Works great! I’ve run this on propane for weeks at a time without any issues other than it’s almost too cold.
Updated led lights on ceiling, floor area, cabinets, and outside. USB charging ports.
- marmoleum floor
- water tank drain upgraded to aluminum / brass valve
Wired for charging from the truck, but would need a dc-dc charger to properly charge the lithium battery. I think this is totally not necessary and the solar has been more than enough to keep the battery full.
Easily accessed extra 12v circuits, could be used for diesel heater or more lights.
Edited by spotfire, 03 April 2021 - 12:09 AM.
