Victron tr smart dc-dc charger settings
Victron charger settings
4 replies to this topic
#1 Northbynortheast
Northbynortheast
  • PipPip
  • 18 posts
Posted 05 April 2021 - 10:16 AM
Hi all,
I just installed a Victron Orion tr smart DC-DC charger in my 2017 Fleet. Can anyone out there share the correct settings for the unit? I’m charging 2 100AH lithium batteries.
Cheers
#2 rando
rando
  • 1,453 posts
  • LocationColorado
Posted 05 April 2021 - 11:13 PM
For most drop in lithiums the following settings will work and yield the longest life:
Absorption Voltage = 14.0v
Float Voltage = 13.4v
Fixed absorption time = 30min
Not sure on what other settings it has, as I don't have one.    Depending on what brand battery you have, you may want to take it up to 14.4v every now and then to get the balancing circuit to work, but you don't need to do that every cycle and it is not ideal for the battery to do that.
Folks who use these can probably chime in about any other settings.
Edited by rando, 05 April 2021 - 11:13 PM.
2016 Fleet Flatbed
2016 Toyota Tacoma
#3 Jon R
Jon R
  • 112 posts
  • LocationWashington State
Posted 06 April 2021 - 01:04 AM
I just bought one of these.  Here's a link to the manual:
https://www.victrone..._Charger-en.pdf
Page 16 describes the chargers settings.
  • 1
Jon R
2021 Grandby Slide-in Front Dinette on order
2021 GMC 3500HD CC LB SRW
#4 kmcintyre
kmcintyre
  • 1,060 posts
  • LocationBoise, ID
Posted 07 April 2021 - 12:48 PM
I think they have a predefined setting for those batteries so that's where I'd start and then adjust as needed.
#5 Jon R
Jon R
  • 112 posts
Posted 07 April 2021 - 05:24 PM
The default absorption time setting is a fixed two hours if you select the preset for lithium batteries. That may be longer than you really want. I would follow the battery manufacturer’s recommendation for voltage settings and absorption time and set the Orion accordingly. It’s easy to do via their Bluetooth interface with your phone.
Jon R
