Truck Antennas
#1
Posted 08 April 2021 - 10:13 PM
#2
Posted 08 April 2021 - 10:24 PM
When I got my after-market XM radio it came with a small magnetic-mount antenna on the end of a long cable. I have it stuck to the hood of my Tacoma a few inches from the front right. I routed the cable under the hood toward the back where I could slip it though the door, then down to under the carpet.
Looks like you can get them from several sellers on eBay, for instance: NEW Sirius XM NGVA3 - Best Satellite Radio Car Antenna on the Market! NGVA1
And on Amazon: Sirius XM High Gain Interoperable Magnetic Satellite Radio Car Antenna
"I'm not an expert; I'm an enthusiast!" - New Mexico, U.S.A - The Land of Enchantment
http://bosquebill.blogspot.com My Travel Blog
http://www.bosquebill.com My New Mexico Website
2013 Toyota Tacoma Access Cab SR5 V6 4x4 - 2013 FWC Fleet
#3
Posted 09 April 2021 - 01:24 AM
~Jim2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#4
Posted 09 April 2021 - 02:53 AM
See if this helps....
SVE Bulletin Q-327
F-Series Relocation Kit For Roof Mounted Dual Antennae
It says, in part...
Beginning in MY2020, Super Duty trucks are equipped with dual roof-mounted antennae that provide modem/cellular, satellite radio and GPS functions. It is recognized that various commercial vehicle upfits involve the use of aerodynamic fairings or other equipment that would obscure the “sky view” that roof-mounted antennae require. There is now available an antenna relocation service kit which provides two replacement antennae that can be mounted on top of the upfit body in a location with a clear sky view.
Service Kit Part Number LC3Z – 18813 – B* * See Ford dealer for latest part level.
(For 2013-2019 Super Duty see SVE Q-293.)
Edited by Old Crow, 09 April 2021 - 03:02 AM.
'01 FWC Hawk shell on a '13 Tundra Double-Cab + '19 Ford Transit van with Quigley 4x4 option
#5
Posted 09 April 2021 - 06:30 AM
#6
Posted 12 April 2021 - 04:16 PM
"I've looked over the various sub-models for the 2020 F-350 pickups and seen that we do not have an antenna that works with the stock satellite radio tuner (appears to be built into the stock radio). Also, at this time, we cannot replace the stock radio in the dash with an aftermarket radio. I wish I had different news for you there.
Good luck! I hope you are able to find a new satellite antenna for it!"
At this point, I'll wait and see how stock system performs.
Edited by michelle_east_county, 12 April 2021 - 04:17 PM.
#7
Posted 26 February 2022 - 11:23 PM
Re radio, AM/FM might be a little worse but it is hard to tell because most automotive tuner/receivers have been marginal since early '80s, same as home audio (RIP, my old Marantz 2330).
Re SiriusXM, reception seems somewhat attenuated overall as over-compressed sound is now even more shrill and harsh than before, and now also cuts out intermittently depending on both direction of travel and angle (going up or down, and side-to-side orientation). I believe a forward camper rooftop solar panel is to blame, as wood and fiberglass of camper would only somewhat attenuate signal.
So, likely on to dual antenna and cable relocation kit per Ford Q-327 discussed above and mount antennas on each front corner of hood as there isn't enough flat horizontal fender to do so. At least the price is now generally down from list of about $345.
#8
Posted 27 February 2022 - 02:23 AM
I downloaded the SiriusXM app on my phone and with the radio apple play I listen to it that way. No need to relocate antenna. Get reception pretty much everywhere.
#9
Posted 27 February 2022 - 02:59 AM
Edited by michelle_east_county, 27 February 2022 - 04:56 AM.
#10
Posted 12 April 2022 - 03:33 PM
How's your GPS/navigation with the camper on? Reading this post is a good consideration about where to mount solar it seems.
