Toyota Tacoma Brakes
14 replies to this topic
#11 zoie
zoie
  • 31 posts
Posted 16 April 2021 - 02:06 AM
you may want to try and do a search on tacomaworld.com and see if there's any info available to help you. At one time I was looking at doing the tundra brake upgrade on my 2003 tacoma but decided I didn't need it. I'm within gvw with my phoenix popup.  I did switch to Hawk pads and I think it helped  but no real data to prove it.
#12 Taku
Taku
    Buffalo Rockface
  • 757 posts
Posted 16 April 2021 - 12:47 PM
On our 05 Tundra with an ATC Ocelot, there is plenty of braking power - given that I drive reasonably and anticipate backing off the throttle instead of charging to the point where I need to use heavy braking power. For almost 8 years, this truck has been driven over Teton Pass (10% grades) with the camper on and in 110K miles have replaced the brake pads once - all stock. Last check is that I will need pads in another few thousand.
2005 Tundra  2013 Ocelot    "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out  "Even more ridiculously comfortable"
#13 fuzzymarindave
fuzzymarindave
  • 255 posts
  • LocationMarin County, CA
Posted 16 April 2021 - 04:31 PM
Upgrade to a vehicle with braking to match the payload and/or towing weight.  Or take a chance and upgrade with larger brakes if a reputable kit is available.   I never expect to increase braking capacity with rotor/pad replacement.   My last vehicle with drum brakes was a 1972 Datsun pickup.    I recently saw a newish Chevy pickup with rear drum brakes.   I imagine there are a few economy cars with them too.
2015 Hawk, Silver Spur Interior, Fiberglass siding.  2008 F250 4x4 Supercab
#14 JaSAn
JaSAn
    Grumpy Old Man
  • 1,103 posts
  • LocationMinnesota
Posted 17 April 2021 - 02:32 PM
Unless you are satisfied with only upgrading pads and rotors I would go to a place with experience upgrading Toyotas for off-road use.  They shouldl have the knowledge of all the changes necessary to upgrade to larger brakes.
Renovating Skoldpaddan
2012 Ram 2500 4X4
1951 Dodge Power Wagon
#15 JHanson
JHanson
  • 488 posts
  • LocationTucson and Fairbanks
Posted 19 April 2021 - 03:34 AM
Sadly, the "experts" often fall prey to the same advertising hype the rest of us do—cross-drilled rotors, larger calipers on stock rotors, and other less-than-worthless modifications.
  • 2
