5 Gal/20 L gas can
gas can
31 replies to this topic
#21 ri-f
ri-f
  • 263 posts
  • LocationPacific Northwest
Posted 22 April 2021 - 04:59 PM
I didn’t think so - I couldn’t even find a place to switch the currency.
I see $39.99 for the water (which is a few dollars more than when I last purchased) and $69.99 for the gasoline cans.
That's correct. Those prices are CDN. I used a currency converter online to see the price in USD.
Speaking of jerry cans, I've had one of these for a few years now and wouldn't go without one.
https://iconlifesave...?v=7516fd43adaa
As long as there's water available (doesn't matter what the quality of the water is like) this will filter it to a safe, excellent tasting level. Great product. Pricey, but no regrets if you tend to go to remote places with limited water on hand.
- 2001 Cummins 2500 quad cab 4x4 turbo diesel; NV4500 5-spd manual transmission; CM aluminum flatbed, '20 FWC Hawk shell - hybrid buildout.  https://ian-frese-of...r.blogspot.com/
- 2004 Jeep TJ - Rubicon
#22 JHanson
JHanson
  • 488 posts
  • LocationTucson and Fairbanks
Posted 22 April 2021 - 06:25 PM
I have never used a Sceptre can whose cap didn't seep in even moderate heat. There's a reason companies sell big wrench-like tools to tighten them. The large diameter cap and gasket simply can't apply enough pressure.
The cammed cap used on the Wavian or surplus NATO cans doesn't leak.
Edited by JHanson, 22 April 2021 - 08:17 PM.
#23 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 23 April 2021 - 01:49 PM
Found the link for the the fill nozzle: https://swissarmyveh...-can-swiss-army
No, they are not inexpensive and yes they are worth it! It took me quite a while to decide to buy one and I'm very glad that I did.
Thom
Where does that road go?
#24 Mighty Dodge Ram
Mighty Dodge Ram
  • 1,003 posts
  • LocationClose to the edge...
Posted 23 April 2021 - 03:36 PM
I have not had luck with plastic cans and am looking to switch to the Wavian...but the lighter 10 liter units. Yes, more costly but my back will enjoy the weight savings.
Richard
1996 Dodge Ram 1500 4x4, lightly lifted, ARB bumper/Warn winch, BFG AT/KO2, Snugtop shell. SOLD! But not forgotten!
2002 Chevy 2500HD XC LB 6.0L 4X4, Leer Hi-Rise shell, completely stock...for now!
#25 ri-f
ri-f
  • 263 posts
Posted 23 April 2021 - 05:03 PM
Your back will also enjoy not lifting a heavy can regardless of whether you use plastic or metal, with a ball siphon hose. Used this for years transferring fuel and water. Leave the can on the ground (raised just a little higher than the tank you're pumping into so gravity will work) and transfer directly to your tank, no spills. Most underrated tool in the box::
https://www.amazon.c...uct_top?ie=UTF8
Rich
Edited by ri-f, 23 April 2021 - 05:08 PM.
#26 Mighty Dodge Ram
Mighty Dodge Ram
  • 1,003 posts
Posted 24 April 2021 - 02:57 PM
✔️ On the “super siphon”, I do have one and used it once when I had cheap HF plastic fuel cans mounted 🤫 to a roof rack. Thanks for the tip Rich!
Richard
#27 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
Posted 25 April 2021 - 02:31 PM
Be warned that the copy siphon from Harbor Fright, if they have not changed it, is too big to fit thru an unleaded fuel restrictor in the fill neck. I was given one a long time ago that was useless because of this.
Thom
#28 ri-f
ri-f
  • 263 posts
Posted 25 April 2021 - 04:45 PM
That's good to know. The one I referred to is a 3/4 inch tube. It has a good flow and will fit pretty much everything. If you do happen to have a hose that won't, for instance, fit into the neck of your vechcle's tank fill, you can always use a funnel or insert a smaller length of tube into the end of the larger tube so it will fit through the neck. Also, be sure to use seperate siphons, one for gas/diesel, and one for drinking water.
#29 Mighty Dodge Ram
Mighty Dodge Ram
  • 1,003 posts
Posted 26 April 2021 - 03:53 PM
Also...I’ve seen them with plastic siphon devices and brass(?) devices. I prefer the brass models.
Richard
#30 Curmudgeon
Curmudgeon
  • 39 posts
  • LocationKlamath County, OR
Posted 27 April 2021 - 03:57 AM
Another vote here for NATO cans.  I have a pile of them I bought about 20 years ago.  Most were decades old and well used when I got them, but still perfectly functional.  Some have German markings and some have Croatian, and the newest are now about 30 years old.  I have never had one leak, even when lying flat in the hot sun.  I'm sure they will outlast me.
I recently bought 4 new cans made by Gelg in Poland.  They claim to be a NATO supplier.  They are visually nearly identical to NATO/Wavian cans, but on closer inspection they are not as good quality.  They are over half a kilo lighter, so obviously made of thinner material.  NATO and Wavian cans both weigh 4.4k, and the Gelg cans weigh 3.8k.  And they just aren't as nicely made.  I'm sure they will work just fine, but I won't buy them again.
Jim Price
curmudgeon: n. a crusty, ill-tempered, irascible, cantankerous old person . . . .
Also tagged with one or more of these keywords: gas can
