I dislike SAE plugs because they flip the polarity each time one is used in a circuit. One has to be very careful if using SAE extensions- you can start out with the protected pin as positive but then on the other end it is the non-protected pin and vice versa.
The connector Zamp uses is an SAE documented design, not a proprietary one. They just reverse the polarity for reasons known only to them.
Too bad they collected Front Runner, am betting that they won't be semi-local much longer.
Of course they are bulkier but I have pretty much standardized all my 12VDC connectors to the Anderson style mostly 50A but I do use a few 350A ones on very high draw items like winches.
Edited by SkyP, 05 June 2021 - 03:23 PM.
