Jack Brackets Detaching
jack brackets fwc
12 replies to this topic
#11 SkyP
SkyP
  • 67 posts
  • LocationSouth Carolina
Posted 08 June 2021 - 10:11 PM
Rivnuts may work but even better IMO are PlusNuts, especially in thinner metal.
https://www.cardinal...ts.com/plusnut/
I used a bunch of PlusNuts building out 2 Transit van interiors- very thin metal.  I defy anyone to pull a plusnut out- rivnuts can come out fairly easy in thin material.
20 F150 4x4 18 ATC Panther
96 F350 4x4 99 FWC Grandby Shell
15 Aliner Scout
18 Camplite 16TBS
#12 Ruck_and_Roll
Ruck_and_Roll
  • 120 posts
  • LocationGrand Junction, Colorado
Posted 10 June 2021 - 12:23 AM
A little update here....
-Good luck funding self tapping screws bigger than what is already on there...went to multiple hardware stores.  You certainly can find something longer, but if you're looking for larger diameter, you're local Home Depot/Lowes/True Value won't have it....
-Ended up using a slightly thicker lag screw (same length) and that seemed to do the trick, so I think I can avoid redrill and/or plus/riv nut for now....
-Talked to FWC, and the gooey stuff is apparently Butyl tape.  Certainly doesn't look like tape, but hey, this is what butyl tape may look like after 13 years.
-On further investigation, the corner bracket actually seems to have gotten bent/warped slightly.  I am sure these are circa 2008, and it is the "2 part" type, so I don't think I have any chance of fitting of the bracket flush against the camper unless I replace.
Thanks again,
Luke
2014 Ford F-150 XLT
2008 FWC Hawk
Western Colorado, USA
Instagram: @lukeyfiasco
#13 wuck
wuck
  • 328 posts
  • LocationPollock Pines, Sebastopol CA
Posted 20 June 2021 - 05:36 AM
In 2016, wuck did this interesting post on using rivnuts to mount the brackets on his 04 Hawk...
wuck's rivnut post from his 'My 04 Hawk' thread
And in this December 2019 post, wuck tells us how the rivnuts he installed three years previous are doing...
wuck's rivnut update in the 'I have a screw loose' thread
Thank you sir!
Rivnut fix still very strong, no issues. Wish I had done a better job painting the brackets before I installed them :)
Pat
Pat
'04 FWC Hawk
'15 F250 SD SuperCab / Short Bed
SuperDuty Mileage (Fuelly)
Trip Photos on Flickr
Also tagged with one or more of these keywords: jack brackets, fwc
