Raising and lowering camper with jacks
14 replies to this topic
#1 Doff
Doff
  • 84 posts
Posted 14 June 2021 - 12:56 AM
Hi all
Wondering if ya’ll have any tips or tricks for raising and lowering your camper? We get ours in 4 weeks!! We plan to keep it on a trailer and use the jacks to raise up it up onto the truck and to lower it down onto the trailer. Wondering if there’s any tricks to mend that process easier? Or do I just need to work one Jack at a time little by little?
#2 DarinH
DarinH
  • Registered (Tapatalk)
  • 118 posts
  • Locationwestern Colorado
Posted 14 June 2021 - 01:45 AM
It's a huge time saver to have 2 people working in unison on each side to raise and lower the camper. If your buying your camper from a FWC dealer, it should come with 2 hand-crank jack tools and 1 jack tool that will fit in a cordless hammer drill. At least mine did, last March. Buy a 2nd drill tool ($30 on Amazon), have 2 hammer drills, and save your arm strength for funner pursuits (like fishing).
#3 jimjxsn
jimjxsn
  • 599 posts
  • LocationRoxborough Park or Buena Vista CO
Posted 14 June 2021 - 02:04 AM
I have a Rieco-Titan wheeled camper stand that is about trailer height.  I got tired of raising and lowering the camper so I built a wood extention on the top of the stand.  With this extension the camper sits at the same height as the truck bed.
When mounting the camper, I raise each corner 5 or 10 cranks and make the switch on or off the truck.
  • 1
~Jim
2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#4 Doff
Doff
  • 84 posts
Posted 14 June 2021 - 06:45 AM
Is there a specific drill bit you suggest I can purchase online?
#5 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,589 posts
  • LocationNortheast Oregon
Posted 14 June 2021 - 12:31 PM
Yes, it’s the adapter for the Rieco Titan jacks.
I am haunted by waters
#6 57Pan
57Pan
  • 118 posts
  • LocationWashington
Posted 14 June 2021 - 02:52 PM
I raise and lower mine by myself, using a cordless drill and one of those jack adapters. Just raising it a little at a time keeping it reasonably level all the way up and down. It makes me a little nervous when it is high enough to slip my truck under it, but that’s just part of the game.
#7 longhorn1
longhorn1
    Ouch, that stings!
  • 2,826 posts
  • LocationCarmel, Indiana
Posted 14 June 2021 - 06:51 PM
2 people. My wife and I start at the back (front or back works) and do 10 cranks each. We move to the front and another 10. We repeat until we have it high enough to back under the camper or until it is lowered onto the storage base. When we load my wife guides me back. Take it slow.
http://texaslonghorns01.blogspot.com/
Ford F-250 Long bed, 2014 Grandby
#8 SkyP
SkyP
  • 112 posts
  • LocationSouth Carolina
Posted 14 June 2021 - 11:35 PM
 Curious why you use hammer drills?
What does it do for jacking that a regular drill won't do.
20 F150 4x4 18 ATC Panther
96 F350 4x4  99 FWC Grandby Shell (sold)
15 Aliner Scout
18 Camplite 16TBS
#9 CougarCouple
CougarCouple
  • 1,376 posts
  • LocationLas Vegas
Posted 15 June 2021 - 02:01 AM
Hello Doff
Congratulations on the upcoming delivery.
Secure the camper with ratchet straps to the trailer. Secure the rear of the trailer before you enter camper on trailer.
Russ
#10 Jon R
Jon R
  • 928 posts
  • LocationWashington State
Posted 15 June 2021 - 04:27 AM
Heavy rubber mallet to make fine adjustments in the jack foot positions allows me to easily get the camper perfectly centered when putting it on the truck..
I also like to use the cranks rather than the drill for touching it down. It gives better control.
If you are on ground that is sloped at all, it’s important to keep the camper level except when it’s in contact with the truck. Otherwise you are putting lateral load on the jacks and mounting brackets. They can handle a little of that but not much.
Jon R
2021 GMC 3500HD CC LB SRW Gas
