Water lines
#1
Posted 30 August 2021 - 01:33 PM
#2
Posted 30 August 2021 - 01:39 PM
#3
Posted 30 August 2021 - 03:02 PM
I don’t have it handy but it is really helpful to see a plumbing diagram to understand the workings of the two valves associated with the hot water tank. In normal usage the upper valve (fill valve) is open and the lower valve (drain valve) is closed. The lower valve drains the tank into the cold water tank. You open it to drain the tank when you want to empty the system or when you want to use the last 6 gallons in the hot water tank because your other tank is nearly depleted. If the drain valve is open, the water heater must be turned off to prevent tank damage.
Edited by Jon R, 30 August 2021 - 03:03 PM.
Jon R
2021 GMC 3500HD CC LB SRW Gas
#4
Posted 30 August 2021 - 04:03 PM
Jon R
#5
Posted 30 August 2021 - 06:09 PM
#6
Posted 30 August 2021 - 08:12 PM
To drain the hot water tank into the cold tank you open the lower (drain) valve and open the hot water faucet to let air into the tank as it empties (pump off of course).
Do you have the manual for your camper? It has a big section on winterizing. If you don’t have it you should be able to pull it up on the fwc web site.
Jon R
#7
Posted 02 September 2021 - 05:22 PM
#8
Posted 02 September 2021 - 06:37 PM
Winter storage or winter use....
If you heat the water in the heater and have room in the 20 gal storage tank...in the winter you can dump/drain the hot water into the storage tank overnight if expecting really low temps and this gives you a larger heated thermal mass outside of the space heated area ...remember the 6 gallon hot water heater only drains out 5 gallons [and outflow line into the storage tank] but remaining one gallon in heater does not pose a threat if it freezes... or, I have been told.. ...trade off is you use more propane...if that cold, I leave cabinet doors open to allow interior forced air heat to enter...
All good....
Phil
#9
Posted 02 September 2021 - 07:38 PM
I wish they would have located the hot water tank switch inside the cabinet.
Edited by Jon R, 02 September 2021 - 07:41 PM.
Jon R
#10
Posted 02 September 2021 - 08:14 PM
so if I understand right, when camping bottom one is turned 90 degrees to keep water in heater an when winterizing it inline with hose!!!right?? thanks!! also inline if I am short on water when boondocking!!!lol
I think you understand the valve function correctly, but I would suggest that the lower valve should only be open when you are doing an operation that requires it to be open to drain the tank. The rest of the time I would keep it closed so you avoid forgetting to close it later. Also, “winterizing” can mean different things. For some of us it means just draining the system. For others it means filling with an antifreeze mixture. So I hesitate to simply say “open for winterizing.”
I think you get it, though.
Jon R
