2006 Hawk Hot Water Heater Not Lighting
hot water heater 2006 hawk pilot light
4 replies to this topic
#1 RamblinRoger
RamblinRoger
    Newbie
  • Pip
  • 5 posts
  • LocationMerced, CA
Posted 16 November 2021 - 10:32 PM
Hello WTW Folks,
I am unable to get the pilot to light on the hot water heater in my 2006 Hawk.
The pilot light will eventually ignite if I use a butane lighter but take a long time.
The main burner will then also ignite. But after a couple minutes both go off. The water is heated only to warm at that point.
Suggestions? Thanks in advance.
Ramblin'Roger
#2 DanoT
DanoT
  • 272 posts
  • LocationSun Peaks, B.C.
Posted 16 November 2021 - 11:07 PM
After my propane fridge has been tuned off and not in use for months, I have had trouble getting a pilot light on a propane fridge to stay lit.
My problem is rust/dirt in the orifice. Lots of blasting with compressed air eventually gets things working but it sometimes takes several attempts over a few days.
Edited by DanoT, 16 November 2021 - 11:08 PM.
1991 Dodge CTD, owned since new. 2011 Coyote RV Phoenix pop-up camper, custom made for the Canadian winter.
#3 Stan@FourWheel
Stan@FourWheel
  • 2,315 posts
  • LocationWoodland, CA
Posted 17 November 2021 - 10:17 PM
The lines usually get clogged over the years.
You might need a new line set.
Something like this.
(new thermocoupler and new pilot light feed line)
https://www.amazon.c...e?ie=UTF8&psc=1
And then blow out the bigger air/propane mixture tube with compressed air.
I've replaced a few over the years.
Usually fire right back up again after cleaning and replacing that part linked above, if nothing else is wrong.
Edited by Stan@FourWheel, 17 November 2021 - 10:20 PM.
Woodland, CA 95776
www.fourwh.com  ---  e-mail = stan@fourwh.com
#4 ckent323
ckent323
  • 1,007 posts
  • LocationSolvang, CA
Posted 17 November 2021 - 11:01 PM
I had a similar problem with our Norcold N300 refrigerator.  After fooling atound with the burner for too long I searched online for replacement parts, bought a replacement burner and installed it.  Problem solved.
I recommend starting with the burner replacement.  If that doesn't do the trick then yu can move on to replacing other parts (thermocouple, etc).
Edited by ckent323, 17 November 2021 - 11:02 PM.
#5 RamblinRoger
RamblinRoger
    Newbie
  • Pip
  • 5 posts
Posted 22 November 2021 - 07:05 PM
Thanks for your feedback DanoT. Much appreciated.
