Mounting a Propane tank on rear ext. wall ?
24 replies to this topic
#1 goinoregon
goinoregon
  • 518 posts
  • LocationPDX
Posted 16 December 2021 - 08:01 PM
Does anyone have a recommendation on a brkt/box to mount a propane tank to the rear exterior wall of camper ?
I was planning on mounting inside, but the more i think about it, the amount of space it requires might not be worth it, for my type of camping.  in the summer, i dont use much propane for cooking, and none for heating.
i am thinking some type of box might be the best choice, as i could use it for carry things in the summer when i dont need a large propane tank, or even remove it.
thx in advance.
Oregon
#2 Jon R
Jon R
  • 925 posts
  • LocationWashington State
Posted 16 December 2021 - 10:34 PM
Since you don’t use much, have you thought about just carrying one or two of those 1 lb green bottles? They could be stored behind a turnbuckle door with some padding so they don’t move around.
Jon R
2021 GMC 3500HD CC LB SRW Gas
#3 Jkron
Jkron
  • 30 posts
  • LocationCO/NH/NY
Posted 17 December 2021 - 12:35 AM
AT Overland makes a bracket for either 5lb or 10lb propane tanks. I have used them in the past mounted to the jack brackets of a FWC.
Fuel, Propane and Water – AT Overland Equipment
#4 Hoopy
Hoopy
  • 84 posts
  • Locationsouthern Wa
Posted 17 December 2021 - 02:56 PM
There is a setup that you can refill the one pound cans.  A friend of ours uses them for their camp kitchen.  You would get your compactness and recycle.  I have seen the exterior brackets as well
#5 Vic Harder
Vic Harder
    Doctor Electric
  • Site Team
  • 4,948 posts
  • LocationCalgary, Alberta
Posted 17 December 2021 - 09:10 PM
+1 on the refillable bottles. If not, a milk crate is the right size.
#6 goinoregon
goinoregon
  • 518 posts
  • LocationPDX
Posted 18 December 2021 - 12:18 AM
Thx guys.  i do have a propex propane, that i need to install, and i figure it would be better with a 5 lb propane tank.
i still have not dressed up the inside of my atc shell, and the more i look at the std propane door, and the space it will take up inside, i am trending away from it.
i will look into the 1 lb refillables.
thx
Oregon
#7 goinoregon
goinoregon
  • 518 posts
  • LocationPDX
Posted 18 December 2021 - 12:24 AM
does the hole pattern on the brkt match up to camper jack brkt holes ??
Oregon
#8 michelle_east_county
  • Registered (Tapatalk)
  • 97 posts
Posted 18 December 2021 - 08:57 AM
My thought on rear exterior mount would-be to mount one high enough to avoid direct impact by a truck or SUV if rear-ended, but not so high it would require a stool every time you retrieved it.
#9 goinoregon
goinoregon
  • 518 posts
  • LocationPDX
Posted 18 December 2021 - 08:24 PM
good idea
Oregon
#10 2Z Bundok
2Z Bundok
  • 40 posts
Posted 19 December 2021 - 09:34 PM
Good Topic! I have been looking all over for:
1. reliable gauge for the onboard tank - use and AM frost is best on trail.  Scale (weight) is the only other reliable way that I have found.
2. Place to "scuttle" another common 20# tank.
 We have run out several times in the cold of the night with thermostat set at 63 deg (pop up TC) and installed 1# back up.  1st the adapter then 1# will last a few hours until the MT is total frost!
 For economy and ease I too want to add a 2nd 20# on the back.  Up high is great suggestion.
2Z Bundok
Truck Camper...The box from which we think outside.
