8020 Aluminum Extrusion
9 replies to this topic
#1 Oryguntroutbum
Oryguntroutbum
  • 396 posts
  • LocationCentral Oregon
Posted 07 January 2022 - 05:02 AM
Could someone tell me what size 8020 slotted aluminum is being used by the factory for the optional tie down rails for the side of the camper? Mostly seen on Project M’s right now.
Thanks
2014 Dodge 2500 4x4, Cummins TD2021 FWC Hawk<p>
#2 LuckyDan
LuckyDan
  • 644 posts
  • LocationBased in Eastern, NOW CENTRAL Oregon
Posted 07 January 2022 - 08:18 AM
If you don’t get a definite answer, Fastenal is a local distributor if you’re unaware. If they have some in stock, IME, they are old school enough they’ll let you hold up some to the side of your Spur in the parking lot to see what looks right.
Good luck.
Old, bum around in Ford and an even older FWC Grandby
New Mantra: "Everyday camping is just making up for lost time"
#3 SigSanDiego
SigSanDiego
  • 85 posts
Posted 07 January 2022 - 02:09 PM
Good luck.
#4 goinoregon
goinoregon
  • 519 posts
  • LocationPDX
Posted 07 January 2022 - 09:04 PM
it  looks to be the 1.5" square extrusion. thats the 15 series.  i like the thinking behind it, and the L-trac in the interior.
i am just starting to mock up some l-trac for my interior floor, and then will go up with some 1" square extrusion, 10 series, to fashion some boxes and shelving for propex furnace, and battery, victron, converter, etc.  the 8020 cuts easily on mitersaw with proper blade.
when i was perusing the 8020 website, the variety of options is mind boggling. i ordered their catalog, and foud it easier to use. then went to website and ordered
Oregon
#5 Oryguntroutbum
Oryguntroutbum
  • 396 posts
Posted 08 January 2022 - 09:32 AM
Thanks. I’ve done L track on my interior floor also. I think it will work well to secure bins and other items while off-road.
#6 Oryguntroutbum
Oryguntroutbum
  • 396 posts
Posted 08 January 2022 - 09:35 AM
Good luck.
Thanks. I forgot about Fastenal. There is one local so I’ll check it out. I no longer have the Spur. I need to update my info. After 5 years with a fully loaded Hawk I finally got my new Hawk Shell in black diamond plate a few weeks ago. Funny how much stuff I found I really didn’t use in my loaded Hawk. I’m loving all the room in the shell.
#7 ntsqd
ntsqd
    Custom User Title
  • 2,881 posts
  • LocationNorth So.CA
Posted 15 January 2022 - 08:05 PM
mcmaster.com is also a good source for 80/20 type stuff. As usual their web page is one of the easiest to navigate and find what you're looking for or even find a solution to your problem without knowing what that solution looked like before the search. There are other brands out there and I've found that some offer parts that others do not. McMaster doesn't source from 80/20 exclusively and that is how I learned that there were other vendors.
Thom
Where does that road go?
#8 BobD
BobD
  • 115 posts
  • LocationFallon, NV
Posted 16 January 2022 - 06:36 PM
US Cargo Control is pretty good to deal with as well.
https://www.uscargoc...Straps-Hardware
2010 Tacoma DCLB   2012 FWC Eagle
2017 F350 4x4 -  Super Doody Flushed
2019 DCLB Tundra - 2012 FWC Granby
#9 Mthomas
Mthomas
  • 137 posts
  • LocationNorth Tahoe
Posted 17 January 2022 - 11:47 PM
There are different weight of these extrusions. Some of them can get pretty heavy.
2018 Hawk FD 2016 Ram 2500 6.7 CTD
#10 Oryguntroutbum
Oryguntroutbum
  • 396 posts
Posted 20 January 2022 - 07:17 AM
Yeah, factory uses the hollow extrusion which is what I will likely do. Solid would be overkill.
