Propane door misaligned
Propane door
15 replies to this topic
#1 Sagebrusher
Sagebrusher
  • 33 posts
  • LocationSagebrush country, USA
Posted 17 January 2022 - 07:32 PM
After no other trauma than badly wash-boarded roads in Death Valley last week, my propane compartment door on my 2019 Hawk Shell became badly misaligned.  I can't see any problem with the hinge nor how to take it apart since it is rivetted on. After a little banging it can be forced shut, but then is hard to open-not good in an emergency.
Anybody have this issue and figure out an easy fix?  Thanks for any suggestions.
2019 Four Wheel Camper Hawk Shell mod on 2018 F150
https://sites.google...gebrushers/home
https://www.youtube....8qMF7m_uaV0F-Dg
#2 fish more
fish more
  • 795 posts
  • LocationSierra Foothills
Posted 17 January 2022 - 08:15 PM
Pictures ?
#3 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,576 posts
  • LocationNortheast Oregon
Posted 17 January 2022 - 08:30 PM
I hope I’m wrong, but I’m wondering if you have something more serious going on.  Assuming the door is on the back wall, can you step back and see if there is any slight twist or buckling siding on the back of the camper.  Maybe measure diagonally to see if the distances are equal.
As fish more said, pictures would help.
I am haunted by waters
#4 Sagebrusher
Sagebrusher
  • 33 posts
Posted 17 January 2022 - 10:05 PM
Good suggestion. The back side diagonals are the same within 1/8 inch.
Here are some pics. It doesn't look like much but it takes several hard whacks to get it to close. Hinge seems fine and is same on top and bottom. My next step may be to take a big hammer to the hinge on the bottom to push it back a little, but thought I'd ask first. Not sure why my pics are sideways after attaching.
#5 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,576 posts
Posted 17 January 2022 - 10:17 PM
Here is a link to the support thread about photo orientation.
#6 Wandering Sagebrush
Wandering Sagebrush
    Free Range Human
  • Site Team
  • 10,576 posts
Posted 17 January 2022 - 10:21 PM
The second picture down makes it look like the bottom of the hinge is stretched out.  If that’s the case, gentle persuasion with a hammer on a block of wood might be the solution.  Something took a good jolt back there.
#7 ski3pin
ski3pin
    Belay On
  • Site Team
  • 15,321 posts
  • LocationSierra Nevada Range
Posted 17 January 2022 - 11:17 PM
I concur, it looks like the hinge was deformed some way. Careful work with a hammer and block and you should be able to get it back in shape.
#8 Sagebrusher
Sagebrusher
  • 33 posts
Posted 17 January 2022 - 11:25 PM
Good eye! And good suggestion. I'll try that.  Thanks much.
#9 PaulT
PaulT
    Need gumbo
  • 2,611 posts
  • LocationHillsboro, Oregon
Posted 17 January 2022 - 11:28 PM
*2
If you have a helper, have them hold a black of wood along left side of the hinge while you hold a second block of would along side the right side of the door and tap the second block of wood until the door is square again & closes.
#10 m5040
m5040
  • 41 posts
  • LocationCT
Posted 17 January 2022 - 11:53 PM
It looks to me that someone opened the door too far, it pressed against the rubber stop bumper and when forced, it then bent the hinge out and that bent hinge now allows the door position to be too close to the striker.
