Solar help. Upgraded lithium battery. Older Tracer charger
11 replies to this topic
#11 BBZ
BBZ
  • 666 posts
  • LocationGolden, CO
Posted 17 March 2022 - 10:51 PM
BBZ, KP is right, that 100/20 is plenty for you.  Jon R is right too... future proofing is good.  You are right too, picking what you need for right now.
As for the correct order of things... I'd disconnect the solar panels first, then the positive wires from the load and the battery, and then the grounds, battery ground last.  Reconnect in the same order unless the owners manual of the Victron says otherwise (which it does, it says to connect the loads first - page 12)
MPPT solar charger manual (victronenergy.com)
Vic
Thanks Vic!
2023 F-150 Scab HDPP + 2013 Grandby Shell +
https://www.wanderth...ect-90s-granby/
#12 BBZ
BBZ
  • 666 posts
Posted 26 March 2022 - 08:40 PM
Hey All
I got my new Victon set up but having issues with BT for the Renogy battery now, it won't connect.
Any thoughts (because I am now connected to the Victron BT??)
Now I can't read if battery is charged or not.. just what the solar is doing..
Help!
