we have an ATC Ocelot on an 05 Tundra AC and the clearance is very tight I would say less than 1/2" on either side. Carefully measure and if it will fit, just need to be very careful and take your time to load. We leave ours on fulltime due to the tight fit.
Concur with "...taking your time to load."
Don't sell anything until you have taken the time to repeatedly slide the Hawk into the bed of theTundra....it takes patience and practice to keep Hawk aligned down the center of the bed and with the same clearance between the wheel wells..
So far I have not heard anyone say that the type of interior design changes the exterior dimensions; nor has anyone said there is a difference in the bed dimensions between my '05 and your '06 Tundra..
Yes it is tight between the tailgate uprights but not so tight that it will not slide all the way forward until the bumpers are against the front of the bed...
Edited by Wallowa, 29 April 2022 - 02:43 AM.
