#11
Posted 29 April 2022 - 10:51 AM
#12
Posted 29 April 2022 - 01:57 PM
Let us know how it goes. That liner does look much thicker than my Tundra which has Line-X.
06 Tundra AC TRD 4x4, 08 Hawk, Ride-Rite bags, Helweg sway bar,18" BFG AT's
2021 RAM 3500 Crew 4x4, 6.4 hemi/8 speed trans with 4.10 gears, Timber Grove bags, Falken Wildpeak 35" tires
2008 FWC Hawk with victron DC-DC charger, 130w solar, MPPT controler
#13
Posted 29 April 2022 - 07:46 PM
FWC specs...shows either dinette style has the same camper width and length ... 80" [outside] x 80".... perhaps I am misinterpreting something?
https://fourwheelcam...2022.pdf?x96940
Just saw this, if it is of any help.
https://itstillruns....cs-7756492.html
https://www4.bing.co...014F41128FFE419
Edited by Wallowa, 01 May 2022 - 06:14 PM.
#14
Posted 01 May 2022 - 06:06 PM
I have a 2013 on a 05 tundra. The screws that hold the corner trim have shaved off the bed liner on the vertical sides. Good news is it won’t shift when on bumpy roads.
#15
Posted 04 May 2022 - 02:01 PM
So, Genesis did you get it installed?
#16
Posted 04 May 2022 - 03:13 PM
I sold a Hawk to someone years ago and helped him load it onto his Gen 1 Tundra. We had the same problem where it needed a half inch clearance between the bed rails. We basically pulled back on the bed from the top rails and gained the clearance we needed to slip the camper on. Good luck!!
2019 Tundra 2019 Panther Shell
#17
Posted 04 May 2022 - 11:20 PM
I asked around in the shop for advice.
They said you would need to grind off most of the spray-on bed liner in the tail gate opening area.
This will give you the needed clearance.
Worst case, you might also need to remove a few of the trim screws or the 2 small bolts for the battery straps (rear / driver's side area).
Hope this helps.
Woodland, CA 95776
www.fourwh.com --- e-mail = stan@fourwh.com
#18
Posted 06 May 2022 - 01:29 AM
I have a 2018 shell with side dinette on a 2006 Tundra DC with a bed mat but no bed liner...about 1/4 inch clearance on both sides.
Also tagged with one or more of these keywords: FWC, Hawk, 1st gen tundra, tundra
