Photo & Attachment Explanation
#11
Posted 30 October 2009 - 10:41 PM
Go to the Gallery, then click on "Members Gallery" then "New Album" give the album a name and then hit "Create Album". You should be able to start uploading from there.
Good luck, hope to see some pics soon.
2003 Four Wheel Camper - Hawk
2017 Toyota Tundra Double Cab Limited 4WD
#12
Posted 30 October 2009 - 10:54 PM
I have had trouble with posting as well and here is what I found with the BB Code
When you copy the BB Code from the gallery and paste it into a post you have to delete the(img) at the front of the BB Code and the (/img) at the end of the BB Code and then it will work. Not sure why or if it's fixable but it is annoying and took a bit to figure out what was going on.
Thats because you are using the image button in the post editor. You don't need to use that, just copy and paste directly from the gallery to the post.
#13
Posted 31 October 2009 - 03:44 PM
Jay,
Sunny Thanks for that. I did a "dry" run and it looks like that does the trick. However, when I try to load a "raw" pic it appears the file is so large it could take days to load. What size are you loading? Also is there a way of loading more than one pic at a time?
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#14
Posted 31 October 2009 - 04:24 PM
Most of my pics are 1.5-2 MB, pretty sure i had to resize them to a smaller size before the gallery would let me upload them. Can't remember how small i resized them. I defer to DD for the rest of your questions.
#15
Posted 31 October 2009 - 10:59 PM
Scott, Valerie and Dukino
2002 Tacoma Ext Cab TRD 4 X 4
2020 FourWheel Fleet, loaded
#16
Posted 31 October 2009 - 11:19 PM
I don't know how to resize. How do I do that?
I use Windows Paint. After loading a picture, I choose the menu item, Image: Stretch/Skew. I make sure that I stretch (shrink) the length and width by the same percentage, then re4-save the picture.
#17
Posted 31 October 2009 - 11:37 PM
thanks
#18
Posted 26 December 2009 - 06:15 PM
I put a picture in my profile to display when I post. It is within the size limitations, but it doesn't show up when I post. What have I done wrong?
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
#19
Posted 27 December 2009 - 04:21 AM
2006 Tacoma, '66 AS Caravel, 2002 Eagle
#20
Posted 27 December 2009 - 04:36 PM
I have had the same problem since being here but I find when I open with another browser and then close both it works.
E.g. Open with Firefox and change avatar. Close Firefox and open Internet Explorer and check to see if the avatar took. Get pissed off because nothings working and close Explorer. Go get a shot of Hornitos and think of all the foul words you can. Re-open Firefox and it should be there. If not there repeat. Good luck. Pictures and avatars on this site have been the bane of my existence. Now with you having the same issue at least I'm in good company.
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
