There's an intermediate solution, but it requires knowledge, skills and the tools to make it happen. That is an inner tube. With the avatar dune buggy a spare really isn't an option, so we all carried the tools and a tube. I mounted one new set of rear tires with those tools just so that I had some practical under my belt. We used motorcycle tires irons and they worked surprisingly well on a 31-10.50R15 tire. I won't kid you, it's work, but it beats walking.
This is the tool that I built to break the beads:
A short piece of chain fits in that slot. The other end of the chain is put over a wheel stud and the lug nut is run down backwards after the chain. On mine, that angled round tube is a socket for the Snap-on 24" breaker bar that I carried for other needs on the buggy. MISF built his similar tool to use the handle from his Hi-Lift jack.
Three tips-
1) Replace the tube annually or just before a big trip.
2) Store the tube in an anti-ESD bag and use a "Seal-A-Meal" type device to evacuate and seal the bag. You don't care about the ESD properties per se, but the reflectorized mylar keeps the suns rays off the rubber and by evacuating and sealing the bag you reduce any effects of ozone.
3) A ratchet strap that reaches all of the way around the tread of the tire in the center can be used to push the beads out by tightening the strap. Can be a HUGE bonus in trying to get the beads to seat.
An a suggestion: Sometimes it's not the tire, but the valve stem that got torn or ripped off or what have you. Carry a couple spares of those and a tool to install them.
