Attaching thermal pack on both ends
#1
Posted 30 May 2022 - 02:35 PM
#2
Posted 30 May 2022 - 06:27 PM
We just added 1” square tabs of adhesive-backed Velcro to the pop-up vinyl. There are two at each of the four upper ends. In each case, one is a few inches in from the corner and the other close to the end of the liner. These grip the existing Velcro on the liner so everything stays together. So far so good, and the corners look much better. There have not been noticeable changes in raising lowering and we’re assuming that, if there was a problem, the minimal velcro attachment would give way before mischief was done.
(This post was edited after I actually got off the couch and went out to see what “we” did.)
Edited by Dirtroadsavant, 30 May 2022 - 06:49 PM.
#3
Posted 30 June 2022 - 12:55 PM
As a follow up, is this still holding up and any issues? I can't stand the corners falling down anymore!
Boise, ID
2022 Chevy 3500 HD
2023 FWC Flatbed Hawk
#4
Posted 30 June 2022 - 05:17 PM
#5
Posted 30 June 2022 - 09:35 PM
It’s working great after about a dozen ups and downs and it is nice not having the droop.
Great... headed out to add some velcro to the corners and around the back.
I figured it'd work on the front as there are those wires that are behind the push boards and the velcro is way thinner than the wire loom.
Thanks!
Kevin
Boise, ID
2022 Chevy 3500 HD
#6
Posted 01 July 2022 - 06:54 PM
#7
Posted 02 July 2022 - 02:00 PM
I've sent an email to FWC about this issue and they stated it should be ok.
Boise, ID
2022 Chevy 3500 HD
#8
Posted 02 July 2022 - 04:44 PM
#9
Posted 09 July 2022 - 02:55 PM
#10
Posted 10 July 2022 - 01:03 AM
We never have attached ours. Liked to be able to pull it out easily to wipe the walls down.
2005 Tundra 2013 Ocelot "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out "Even more ridiculously comfortable"
