Specifically, it is the rivets leaving round black marks on the ceiling cloth. Is there supposed to be a backing on those to prevent that? I will be taking the panels off to have a look see....
Vic
Posted 01 June 2022 - 06:30 PM
Vic
2015 Silverado 3500 crew cab 8' bed Diesel
Posted 01 June 2022 - 06:41 PM
Vic, I’m not aware of any backing, nor have I heard of this. Assuming this is the front, chance you have extra bedding that is pushing the panels up? Photos?
Real Dogs Have Beards - Fear the Beard
Tu Ne Cede Malis
Posted 01 June 2022 - 06:50 PM
Aluminum pop rivits? I could see that happening if they have any movement against the ceiling. Which is probably likely. MAybe some sort of adhesive mylar dots applied over each rivit assuming the smooth side is up????
20 F150 4x4 18 ATC Panther
96 F350 4x4 99 FWC Grandby Shell
15 Aliner Scout
18 Camplite 16TBS
Posted 01 June 2022 - 08:05 PM
I believe we have mild rivet marks on our ceiling from the lift panels after 9+ years, mainly over the bed area. I'll look and photograph the next time we lift the top at home.
2003 Ford Ranger FX4 Level II 2013 ATC Bobcat SE "And in the end, it's not the years in your life that count. It's the life in your years."- Abraham Lincoln http://ski3pin.blogspot.com/
Posted 06 June 2022 - 11:55 AM
The lift push bar thing leaves marks on the ceiling above the bed. Just about any metal will leave marks after a while, but aluminum is the worst. Wrap or cover in clear packing tape, problem solved.
Trucks, Campers, Gear Forums →
Gear Exchange →
For Sale: FWC DoorStarted by Mote , 13 Aug 2022 ![]() |
Gear Exchange →
2018 FWC Fleet $23,500Started by 252chad , 03 Aug 2022 ![]() |
Gear Exchange →
2018 FWC Fleet for saleStarted by 252chad , 27 Jul 2022 ![]() |
Gear Exchange →
For Sale - Four Wheel Camper & Toyota Tacoma Combo @ $72k obo| Rocklin, CAStarted by TRDCAMPER , 23 Jul 2022 ![]() |
Gear Exchange →
For Sale: 2003 Hawk Camper - minor fixerStarted by edenp , 17 Jul 2022 ![]() |
