Lithium SOC
#21
Posted 12 August 2022 - 03:16 PM
Yes, ideally the negative main draw/return would be on a different battery than the main connection. I have two 100AH BB in parallel, and that’s what I did.
2015 Silverado 3500 crew cab 8' bed Diesel
#22
Posted 12 August 2022 - 04:05 PM
Sorry, Need to mention … no inverter, horizontal 55cfx dometic fridge, FWC furnace, FWC internal LED lighting, small 1.3gal/min water pump, only used briefly ~1/day, 2 - DIY installed variable speed fans in 2 roof vents, 2 outdoor FWC LED porch lights (only use with active bears about), FWC flood lights (glad I have but never used)
Edited by Stokeme, 12 August 2022 - 05:51 PM.
#23
Posted 12 August 2022 - 07:06 PM
