Hello,
I got a brand new 2022 hawk the spring. I took it out a handful of times in cooler weather and the furnace works fantastic. Coldest nights/mornings probably upper 30s. Elevation not more than 5000 feet. Haven't used the furnace all summer.
Did a trip this weekend to the mountains. Was probably between 6500–8700 feet. Tried to light the furnace late in the evening, probably high 30's- low 40's. The fan would come on each time without issue. I would hear the clicking of the igniter followed by the whoosh of it lighting up (I guess that's what that sound is). However, the whoosh sound would only last for a few seconds before "burning out". After multiple tries the whoosh wouldn't even happen.
We bundled up for a chilly night. It was in the low 30s the next morning. Not surprisingly, the furnace wouldn't light. Interestingly, the stove would barely light. I could hear and smell (though not that strong) propane but it was a very weak flame. After a while and multiple tries the stove returned to normal function.
We drove up to about 8700 feet and went hiking all day. Temperatures were in the mid 50s. Back at the camper in the early evening I decided to try the furnace again. Much to my surprise it lit and stayed lit! I turned it off to see if it would work again. Unfortunately, it was one and done...never lit again.
Today at home at 2700 feet it's in the 60s and everything is working flawlessly.
I know this wasn't a power issue because my batteries are brand new and my solar panel was reading fully charged/float mode.
Any ideas what was causing the issue? I've done a little reading and it sounds like elevation and cold temps can cause problems with the pressure regulator? I never had this issue in a pop-up trailer I used to have. I've had camp stoves burn a little weak at elevation/very cold temps but they always worked.
Any ideas?
Thanks
