2010 Hawk - Add propane furnace in "small vent configuration"
hawk furnace
3 replies to this topic
#1 cbamos
cbamos
    Newbie
  • Pip
  • 8 posts
  • LocationBellingham, WA
Posted 04 October 2022 - 05:25 PM
Hello all - I've been using (and loving) a 2010 Hawk w/ rollover chouch since purchasing (through this forum) in 2015, and I am looking for guidance on adding a propane furnace. I've reached out to Stan at FWC, who told me that simply adding the current Dometic unit DFSD 12111 would not simply be "plug and play" due to differences in the camper framing in newer models.
Not knowing a ton about these units, I'm wondering about the Dometic DFSD16121 installed in the "small vent configuration." From looking over the manual, this unit would seemingly fit in the cabinet space circled in the attached image, and can be vented using only a 3.5" diameter wall hole through the camper side.
Question - what am I missing here? Has anyone else performed this sort of installation, putting a new propane furnace in an older camper using the existing cabinet layout? What should I be looking for to ensure that the furnace will fit, and that installing using only the small vent hole will work for our application.
My hope is to simply duct the furnace through front of the cabinet vent using the Dometic 30260 front vent.
Thanks for your help and advice.
P.S. I have researched and considered the diesel heater options, but would prefer to use the onboard propane and keep things as "stock-like" as possible. Also, the Mr. Buddy hasn't been all that useful for us with dogs and kids in the camper.
Slider fridge
#2 Vic Harder
Vic Harder
    Doctor Electric
  • 4,361 posts
  • LocationCalgary, Alberta
Posted 04 October 2022 - 06:44 PM
Almost anything is possible.  I mounted a Propex brand heater in my latest build as shown in the picture.  That is the larger of the available Propex heaters, and we quite like it there.
P3250021 - Vic's Puma (Grandby) build - Gallery - Wander the West
2015 Silverado 3500 crew cab 8' bed Diesel
2012 ATC Puma Shell build - https://www.wanderth...012-puma-build/
Power considerations thread - https://www.wanderth...e-power-scotty/
Building out an electrical system - So, you want to setup a good electrical system in your camper? - Electrical, Charging, Solar, Batteries and Generators - Wander the West
#3 Taku
Taku
    Buffalo Rockface
  • 674 posts
Posted 08 October 2022 - 12:16 PM
you might look at the newer Propex furnace that is designed to mount outside the camper
2005 Tundra  2013 Ocelot    "Ridiculously comfortable"
2021 Tundra 2022 Cougar Shell Built Out  "Even more ridiculously comfortable"
#4 Jamesiam
Jamesiam
  • 235 posts
  • LocationStateline Nevada
Posted 12 October 2022 - 03:29 AM
Watching this topic as well. Just purchased a 2015 Fleet with no heater and was going down the same avenue.
Was looking at the DFSD 12111 as well. Also have a cabinet right next to fridge that seems like a perfect size for the forced air furnace. My biggest issue will be running a gas line to it and of course the little things that always come up.
Also tagged with one or more of these keywords: hawk, furnace
