Ghost In My Roof Vent
#21
Posted 07 February 2023 - 04:09 PM
#22
Posted 07 February 2023 - 04:55 PM
Usually no need to replace to goop on the roof, if you are adding the same brand of fan. I took out the vent in mine and replaced it with a fantastic fan by just dropping the fan guts into the hole and wiring it up.
Interesting!!!!!!!! That would be a best case scenario. A question for FWC to see if the vent and Maxx Air fan are interchangeable.
#23
Posted 07 February 2023 - 05:01 PM
Sounds like a warranty issue, if only 6 months old.
#24
Posted 07 February 2023 - 05:10 PM
Has happened on my Bundutec Sable. I tighten as much as I can, sometimes it stays sometimes it doesn't....Need bungee but have to remove screen to get to it....
2018 Ford F-250. Customized Bundutec Sable
#25
Posted 07 February 2023 - 05:48 PM
You could google the installation manuals for each. They should list the opening dimensions. I suspect they are identical.
#26
Posted 07 February 2023 - 10:07 PM
I recently replaced my fantastic fan with a maxx air and getting the goop off was quite easy. I'd been dreading doing it but the project was quite easy. Worst part was the laying on the roof and try to make sure I didn't dent the roof.
#27
Posted 08 February 2023 - 02:16 AM
Good to know, thanks!
#28
Posted 08 February 2023 - 02:30 AM
I just received prompt word from FWC. They will take out the defective vent and replace it with a Maxx-Air fan under warranty. My props go out to FWC for standing behind their product and components.
#29
Posted 08 February 2023 - 07:50 PM
FWC and ATC have always stood behind their products.
#30
Posted 08 February 2023 - 10:50 PM
Hey, quick question for those who are running the Maxx-Air fans.
Is there a way to open the fan just a few inches, or is it all or nothing????
