Relocating Ford antennas for FWC
Yonder37
Sep 18, 2022
25
Ordered F-150 HDPP in September 2022, it was delivered in January 2023. Ordered FWC Hawk in October 2022, it will be installed in March 2023.
Late-model F-150s and F-250s have two "warts" on the back edge of the cab roof. The warts are actually the antennas used by the vehicle GPS and the SiriusXM satellite radio. They will be completely covered by the cabover part of the camper after installation. Since FWCs have aluminum roofs, I suspected that this would cripple the antennas. Asked around and confirmed that this is an issue.
After I got the truck, I took it to the most experienced car stereo installers in my area. I was thinking they could somehow disconnect the two warts and move them from the back of the cab to the front, where they would be less affected by the camper. I was told that this wasn't feasible.
Instead, they left the warts in place, but unplugged them from the central radio/display on the dashboard. Then they plugged in compatible new antennas, which were mounted towards the front of the truck. The new GPS antenna is inside on the dashboard. The new SiriusXM antenna is outside on the cowling, it does not interfere with the opening of the hood.
The nav system and sat radio both seem to be working normally with the new antennas. Seems like they should be completely unaffected by the addition of the camper next month.
Cost was about $60 for the new SiriusXM antenna and cable, $50 for the new GPS antenna, and $340 for labor, so about $450 total. Hard part was tearing apart the dashboard to get to the antenna plugs, then reassembling it.
Yonder, thanks for posting. Looking forward to your assessment once you get your new Hawk (congrats!) on the truck.
Do you have details on what models the replacement antennas are? (They may be on your bill from the installers)
I encountered the same problem with my diesel powered 2020 Ford F-250, SXT, but since my system uses the Waze app on my phone when it's plugged into the USB port, low on the dashboard, I only had the Sirius antenna. My installer also left the old antenna in place and added another one. I don't know the make or model of the replacement but I'm getting very good (but not excellent) reception. I'm in Los Angeles and they said that's the best that can be expected around here. It was excellent before I was forced to change it. Now in some areas and when driving in some directions (mostly north) the reception cuts in and out.
It seems pretty short sighted of Ford to have placed the "warts" in that location, knowing that many of us will put on campers that will effectively "blind" them.
ETA: My installer mounted the new antenna near the top of the windshield where the roof just starts to curve down.
No, sorry, and the invoice does not include those details. I could give you contact info for the guy who did the installation, he seemed proud that he made it work, would probably be happy to discuss.
The sat radio antenna puck is labelled "SiriusXM" on the top; my impression is that it was nothing unusual. There was more info printed on the base; should have taken a picture before it was attached. The shop seemed confident that the sat radio would not be an issue; they were more concerned about the GPS.
The GPS module has a bunch of info that is visible on the top. Will post a picture of that later.
My route back from the stereo place with the new antennas was south. Have not tried driving north yet.
I added some pix to my post, just above. Yonder37 I think that your Sirius antenna may be in a better position than mine. Where are you located?
Close up pictures attached.
The SiriusXM antenna looks like it could be a common NGVA3 unit, but don't know for sure. The info is on the base, but it's stuck firmly on the cowling and I don't want to pry it off (the cowling is plastic, so the antenna is held is place by adhesive, not a magnet). I was also charged for a satellite radio cable adapter, so an additional part was apparently needed.
The GPS module has info printed on the top. Was not charged for an adapter, so apparently none was needed. My impression is that the GPS antenna was the main concern. The installer seemed confident from the start that he could find and install a compatible SiriusXM antenna, but had to do some research on the GPS antenna.
My truck is a basic 2023 F-150 XL with an 8" touchscreen on the radio/display unit in the dashboard. The installer asked specifically about the touchscreen size. Other F-150 trims come with different radio/display units with larger touchscreens. So it seems possible that the parts are not necessarily identical for all late-model F-150 or F-250 trims.
We discussed putting it at the top of the windshield, but the installer thought that it would work better on the cowling, due to the proximity of the camper.
​Also in California, but in the central part of the state, between LA and the Bay Area.
I don't know the make or model of the replacement but I'm getting very good (but not excellent) reception. ... My installer mounted the new antenna near the top of the windshield where the roof just starts to curve down.
Your replacement antenna looks similar to mine, but since it is mounted on the metal roof, it might be attached magnetically. If so, you may be able to lift it off. The model info should be printed on the base.
That's not gonna work. Most all of my body panels are aluminum. Gotta save weight yaknow.
So I just tackled this issue on my 2022 F250 Super Duty
1. Found where the roof antenna was connected to the line into the back of the SNYC 3 unit. It is actually on the driver side back corner of the roof. If you remove your coat hanger hook then pop out headline then pop away the plastic around your seat belt you'll see it and the GPS antenna. The [Purple] is for GPS. Leave that in place. The [Curry] pea-green one is the SiriusXM antenna.
See attached images of items I purchased on Amazon.
NOTE: you'll need to cut the metal connectors off and splice the two wires together. Make sure to use shrink tube for the actual satellite wire AND the outer copper that shields it.
2. When you go to release the antenna you'll see a tab. Press that tab towards the center of your cab and the other end will easily come out. I thought it was the opposite and struggled needlessly.
3. I put my antenna on the roof of my FWC Hawk Flatbed. I have a galvanized piece of steel up there for my GMRS antenna and have that attached to the Yakima rails. The antenna is BOTH magnetic and has good 3M adhesive on it so you could just clean a spot on the roof with alcohol and stick it up there.
4. Ran the cable down under the cab and came up through the plastic grommet behind passenger seat.
5. From there I ran under the floor liner to driver side and up the rear pillar making sure it was behind the airbag stuff.
6. Plugged it in and I was good-to-go.
full
full
full
The ford antenna relocate kit works fine for 2022 and sync 3 trucks. The new 2023 sync 4 trucks have a different set of wires for the gps antenna. the sync 4 antenna uses two wires from the antenna to the low noise amplifier on the back wall of the truck. I removed the headliner to install dynamat sound reducer. I moved the antenna to the front of the cab. I made a coaxial extension for all the wires from the antenna to the back of the cab. The antenna wires are rg 74 size. The wires at the back of the cab are rg 58. So you need to buy two different size sma connectors and 3 pieces of rg 74 coaxial cable 60 inches long. It was a difficult job to move the antenna and install the dynamat. It is also hard to get at the radio. There are two 10 mm bolts that are hidden 4 inches deep in a slot behind the 12 inch screen. Use a magnetic tool to hold the bolts. The 2023 are different from the 2022. But U tube will get you started.
A small clarification on this post: On these connections- the purple/pink colored connection is for the primary modem/cell tower antenna (20-22 F250's). The pea-green/curry/mustard colored connection is for the Sat radio & GPS antenna. It goes through a splitter under the dash, which separates out the sat radio feed from the GPS feed. Just wanted to make sure people understand what they will be affecting here.
As an update for a 2024 F250:
- I read through the Ford Service manual and wiring diagrams, and it’s very complex. My VIN shows that BOTH roof pods have cellular and also GPS, the DS one includes XM Sat antenna too.
- There are actually 4 cell antennas built in across both pods, primary and secondary, and 2 which are receive only.
- Truck is a Lariat Ultimate with modem and hands free and voice activation, which I think complicates the setup.
- Will be adding a FWC Hawk soon.
- PS pod runs GPS to the telematics unit for Ford Pass type functions, the DS pod runs GPS to the Nav it looks.
- That DS GPS runs up to the APIM in the lower center dash. Supposedly a black coax with a dark blue single center pin Fakra connector, which I could not find.
- However today I found, on the wiring info from Ford, another inline Yellow intermediate Fakra connector in the center dash area, for that wiring run. Not sure if it’s there as I had the dash closed up, but this is where I may look if I need to, but I don’t use the Sync Nav anyway.
In Summary,
- Due to complexity, I went with a separate XM Sat antenna and plugged it into the back of the ACM in the upper center dash, below that tray on top.
- Blue connector on the far LEFT is Sat antenna, in the pic. It needs a Fakra Z Female connector. Try to get a shorter one that I did, it’s very tight once installed.
- I mounted the antenna to the PS front cowl area below the windshield.
Good news, it works great! Hope this helps someone ?
Mark
Latest posts
