Edited by Jon R, 09 March 2023 - 12:53 AM.
Rig Build with FWC Hawk
#31
Posted 09 March 2023 - 12:32 AM
Jon R
2021 GMC 3500HD CC LB SRW Gas
#32
Posted 09 March 2023 - 03:16 AM
The optional dongle-style modules for the DLS-30 were called IQ4 as you describe. There is a module for lithium batteries. The actual model called the DLS-30/IQ4, though, has no ability to use the IQ4 modules (go figure), and is designed for AGM batteries. That’s what i have in my 2021 Grandby, and it’s what FWC has been installing for the last few years. It does not charge my lithium battery in any useful way (you’ve read that story). It sounds like FWC recently changed to another brand.
Yes when I called FWC they told me they are just now switching to Victron's Blue Smart Chargers. Surprised still that its taken this long!
#33
Posted 09 March 2023 - 04:04 AM
If you don’t have a battery monitor you might want to consider that as one of your early purchases.
Jon R
#34
Posted 09 March 2023 - 02:20 PM
So if understand correctly, the charger that I am replacing is only converting 120v shore power to 12v power that charges the lithium battery. The lithium battery then provides power to my panel that then all of the 12v appliances run off of.
Therefore, the Victron converter/charger (120v in -> 12v out) only needs to charge my battery up.
My next question then, should I wire my truck to the camper via the stock wiring since I am now charging a lithium battery? I have been told that the lithium will pull a constant drain on my alternator and fry it...
#35
Posted 09 March 2023 - 05:40 PM
When it turns on, it will come up in either power supply mode or charger mode depending on whether it senses the presence of a battery. The mode and stage of battery charging it thinks it should be in determines what it does with the output voltage.
The positive output of the DLS30 is connected to the supply bus bar of the 12 VDC fuse panel. The positive wire from the truck connector is also connected to this bus bar via the Blue Sea ACR. The battery is connect to this same bus bar via the round silver battery switch. I BELIEVE the solar wires coming from the solar charger, if you have one from the factory, are connected directly to the battery so the solar system can charge the battery even when the silver kill switch is off (can someone with factory solar please confirm this?).
So, even with the battery switch off or the battery removed, the DLS30 can function as a 30 amp 120 ac to 12 vdc converter and power everything in your camper. If an AGM battery is connected and the battery switch is on, the DLS30 will sense the battery and be in charger mode, but your camper loads can steal current from it. That’s Ok.
The inability of the DLS30 to charge a lithium battery effectively stems from the higher lithium battery voltage at partial charge being higher than the voltages the DLS is looking for to decide on being a charger or what stage of charging to be in. If you are at a mid level charge, it senses a near-fully-charged AGM battery and seems to come up in float mode. In this mode it delivers about 13.4 volts, and only a few amps flow into the battery. This flow tapers off as the battery voltage approaches the float supply voltage and the battery never can charge fully.
Regarding your last question, it really is best to do your charging from the truck via a dc to dc converter. It will compensate for voltage loss from the wire run resistance allowing you to charge at the full intended current, it will limit the charging current to the intended level thus protecting your alternator, it will control charging to only charge when the engine is running, and it will actively control the charging of your battery. Many of us have 30 amp Victron Orion Smart dc to dc chargers. In my opinion you should place this charger next to the camper battery to minimize the length of its output wire run, and use 6 awg wire all the way from the truck battery to the charger. This means you are replacing the exterior wire run on the camper and a few feet inside the camper. This charger and the solar charger should be connected directly to the battery (not the camper fuse panel) via appropriate bus bars and fuses.
I’ll let you ask questions rather than going on and on.
Jon R
#36
Posted 09 March 2023 - 06:04 PM
The current charger you have, which I assume is an Iota DLS30/IQ4, turns on when you connect to shore power, turn on the main 120 VAC breaker on the camper panel, and turn on the individual breaker for the converter.
Will the Victron Smart Charger IP22 do the same thing as the DLS-30 IQ/4 then regarding the converting to the 12v breaker panel?
So the Orion connects straight to truck battery terminals (with an inline fuse) and straight to the camper battery terminals? If thats the case, I'll likely add this instead of using the factory wiring.
Questions in red above! Thank you for the explanations!
#37
Posted 09 March 2023 - 07:41 PM
Second question: You would locate the Orion in the camper very near the camper battery. You would run 6 awg positive and negative wires from the truck engine compartment, through a bed connection of your choice (I used an SB50 with rubber environmental boots), and continue the 6awg wire all the way into the camper and into the Orion input terminals.
The positive wire at the truck end would be connected the truck battery positive terminal or battery fuse block, and be fused at that battery with a 50 to 80 amp fuse (max current to the Orion 12/12-30 is 35 to 40 amps).
The negative at the truck end would connect to the truck battery negative terminal or to a large body ground stud directly connected to the truck battery, pass through the connector at the bed, and go to the negative connection on the Orion, possibly via a negative bus bar (if you use the non-isolated model). If you use the isolated ground version of the Orion your negative wire from the truck would go straight to the negative input on the Orion.
No fuse needed for the positive wire from the truck at the Orion end of the wire because current can’t flow back from the Orion in the case of a short to ground, and even if it could your fuse at the camper battery would protect this wire.
The output positive and negative of the Orion would be connected to the positive and negative of the camper battery, probably via bus bars.
All connections to the camper battery positive should go through an appropriately sized fuse or circuit breaker (fuse sizing is an additional discussion) to prevent wire shorts or equipment failure from overheating your wire. All connections to the camper battery negative should pass through the shunt for your battery monitor. I found having large positive and negative bus bars allowed me to keep the wiring much neater and made it easier to be sure it was installed correctly.
I’ll post a picture of my wiring in my battery compartment showing the bus bars, fuse block, shunt, and chargers. My compartment in the cabinet should be identical to yours, so you can see how I laid mine out.
Edited by Jon R, 09 March 2023 - 07:44 PM.
Jon R
#39
Posted 09 March 2023 - 07:59 PM
First question: yes it will. If you wire it in the same way the DLS30 was wired it will function the same way, except it will do a proper job charging your lithium battery.
Picture of Grandby FD battery compartment wiring
Thank you! I am confident that I am going to be able to retrofit the camper now without burning it down! I searched for this camper for years and would be quite sad if I messed it up!
I will report back with updates as I get the camper wired and ready!
The truck is going under the knife in the next few days for airbags and suspension upgrades as well as new tires for adventuring!
Edited by jclifb, 09 March 2023 - 07:59 PM.
#40
Posted 10 March 2023 - 10:37 PM
Spent a couple of hours rewiring the camper to be lithium-ready for when my battery arrives tomorrow. I removed the old AGM charger/converter and wired in this Victron charger that you all suggested and help me figure out! Thank you to all who assisted!
It was not easy, as the fit is very tight in this cabinetry, but I am happy in the end with the result.
