Hodaka"Pops" Scout YOHO Camper Thread.
35 replies to this topic
#31 Hodakaguy
Hodakaguy
  • 641 posts
Posted 15 October 2023 - 01:09 PM
Time for a mattress upgrade!
The 3" mattress that came in the YOHO is waaaaaay to firm for our liking, making for an uncomfortable sleep.  We ordered up a 5" Gel/Memory Foam mattress in Medium Firm and set to work installing it.
Supplies used:
Note: Some of the links below are my Amazon Affiliate links, I make a small portion each time someone purchases from Amazon using one of my links, at no extra cost to the buyer. I only provide links to items that I personally like and use myself. i use the money to put back into my builds and support making videos/posts. If you prefer not to use my links you can search for the same items directly off Amazon. Thank you for the support!
FDW 5" Mattress: CLICK HERE
3M 90 Glue: CLICK HERE
Electric Bread Knife: CLICK HERE
The stock YOHO Mattress.
Removing the original mattress from the cover.  The cover is well built and we will modify/re-use this cover with the new mattress.
New vs Old.  You can see that the fire blanket on the OEM mattress is coming unglued.   I'm betting they are ordering mattresses, removing the fire blanket, cutting the foam to fit and re-gluing the fire blanket back into place.
Here I'm doing the same process I just described, I've cut open the fire blanket so I can remove it to cut the foam to size.   The fire blanket will be re-installed and the seams glued back in place with a bit of 3M 90 after the foam is cut to size.
Using the old mattress as a template I traced the outline onto the new mattress.
An electric bread knife works great for cutting foam and leaves a nice clean cut.
Our cat kept wanting to attack the knife blades lol, had to keep her out of the way.
The new mattress is 1.75" thicker than the old unit.
With the mattress cut to size and the fire blanket re-installed it's time to get out the sewing machine and modify the cover.    The cover is made to fit the stock 3" mattress and needs to have some material added to it to accept the new 5" mattress.   We could have just put the new mattress in a new zip up RV mattress cover but the stock cover is very nice and matches the interior so we decided to modify/reuse it.
The bottom of the cover is vinyl, we will rip out the stitches and add the new material between the vinyl bottom and the upper cover.
Separated.
Cutting some filler material out of outdoor grey duck fabric.   The solid grey should work well in this application.
I used seam tape to secure the new material to the vinyl bottom, this holds it in place and you sew right through the tape.   Works sooooo nice!
Continued Below....
My 4wd Sprinter Build: CLICK HERE
My Unimog U1300L Build:  CLICK HERE
My VW Syncro Westy Build:  CLICK HERE
My Tacoma/FWC  Builds: CLICK HERE
Ride Report - In Memory Of The Crewmen: CLICK HERE
#32 Hodakaguy
Hodakaguy
  • 641 posts
Posted 15 October 2023 - 01:10 PM
Continued from above...
And sewing it all back together.
And the cover back on the new mattress.
Unfortunately I started and ended on the front side of the mattress instead of the rear and ended up with a couple spots that bunched.  Is what it is....Dang!   Still new to this sewing stuff but it's fun learning.   Luckily it will be covered with the sheets.
The new mattress is a LOT more comfortable than the original unit, well worth the upgrade!
Hodakaguy
#33 Hodakaguy
Hodakaguy
  • 641 posts
Posted 15 October 2023 - 10:23 PM
Scout YOHO Fridge Hold Open Mod.
When opening the lid on the fridge the bed cushion keeps the lid from being able to stay open on its own, resulting in having to hold the lid open with one hand while loading the fridge with the other...not the most convenient setup. Time for a fix!
Supplies used:
Door Stop: CLICK HERE
Adhesive Felt:  CLICK HERE
Here's a photo of the stock setup.  The cushion is close to the fridge, a limitation of maximizing space in such a small camper.
I'll be using this metal door stopper as the fridge door catch.  The arm is 4" and the unit is nice and sturdy, it has indents that keep the arm in the up or out position....perfect!
Here I'm removing the end of the arm that holds the rubber foot.  You could leave it as is and it would work the same but I prefer the more finished look that cutting it off provides.
Next I rounded the edges and painted the bare metal.
I added a piece of self adhesive felt to the back side to give the fridge door something soft to contact.  The arm contacts the plastic door itself and not the seal on the door so there is no worries for damage.
Mounting up the new door catch.
And mounted!   The unit looks great (Well in my opinion anyways lol) and is out of the way until needed.   It's easily engaged with one hand (See video below) and is Waaaaay nicer than having to hold it open manually.
Here's a quick Youtube video showing the fridge door in action both before and after the mod.
https://youtu.be/SUF...LyWdQyOcpmbtH0M
Hodakaguy
Edited by Hodakaguy, 15 October 2023 - 10:25 PM.
#34 Hodakaguy
Hodakaguy
  • 641 posts
Posted 08 November 2023 - 01:24 PM
Just returned from a family road trip through NV. We had a great time chasing history, hunting ghost towns and soaking in all of the amazing views. We also jumped into CA a bit to check out the ghost town of Cerro Gordo. Soooo much to explore out there!
Waaaaaaay to many pics to post here. I have all the pics posted and arranged by day on my Facebook travel Page, feel free to join and follow along: https://m.facebook.c...mibextid=IwceVr
Here's a few pics from the trip.
Hodakaguy
#35 Gentle on my world
Gentle on my world
  • 69 posts
  • LocationTeddy's Place
Posted 08 November 2023 - 01:35 PM
I chose Pic No. 4 of the set in Post #34.
Edited by Gentle on my world, 08 November 2023 - 06:32 PM.
#36 goinoregon
goinoregon
  • 479 posts
  • LocationPDX
Posted 08 November 2023 - 06:22 PM
Nice work.  that sewing machine... case is interesting.  keep on sharing.
Oregon
