Oh YEAH!
With much help from Overland Hadley and others in this thread my roof lifting helper thingys are installed on the inside of my Finch.
I wasn't able to get pics since I finished after dark. The 50lb struts are perfect for my roof with the Yakima Tracks, nothing else up top yet. The roof lifts up easily and comes down easily. At first I thought the 50lb might be too much but it is perfect.
Within the last few days I thought I had it figured out. Popped it up and then was in a dilemma and didn't have a solution. I really thought with the Finch something was different. Well with some insight from Hadley I popped it up again today and started again looking at lining things up. Well that did it. Got them installed in about 2 hours. Now mine isn't as clean since I used off the shelf 2x5 tie plates but I am more than happy.
The parts:
Disregard the larger tie plates. I went back to the hardware store and got more of the smaller ones and they worked great. More pics tomorrow.
Parts were purchased from the following:
McMaster-Carr
Struts: 9416K23 Gas Spring with Threaded Ends, 33.94" Extended Length, 16.14" Stroke $22.28
End fittings: Zinc Part#9416K88 $1.62
Bimini Fittings:
http://www.marinepar...ehiwirepin.html
~$7.00 each
2x5 Tie Plates from Lowes, these were about ;0.55 each
Slight update, I don't feel the tie plates are necessary with the fittings.
Small screws-various prices.
I've also found the spring loaded pins on McMaster but not sure which size is needed but wanted to share it for reference.
http://www.mcmaster....s-pins/=13kda5z
Edited by ETAV8R, 05 September 2016 - 02:44 AM.
Founder of D.E.R.P. Desert Exploration & Research Project. A camp proper is a nomads biding place. He may occupy it for a season or only for a single night, according as the site and its surroundings please or do not please the wanderers whim- Horace Kephart.
2009 4x4 Tacoma Access Cab-The Gini
2013 Silver Spur Finch Shell- The Oxcart/Gini's Burden-
http://www.wanderthe...ory/#entry83606
