I second this. Even with a large rigid panel, as long as it’s only one panel, this will be the optimum configuration.Once you install a rigid solar panel with whatever mounting hardware, the two 40 lb gas struts up front will be just about right. With the solar install I have pair of 40 lb struts on the front and 30 lb struts on the rear.
On mine, described above with two 200 watt panels at a total of 53 lbs, it was a tossup between 30# and 40# struts for the rear. The front definitely was better with 40#.
Edited by Jon R, 18 February 2023 - 03:32 PM.
