For Sale:
2006 Chevy 2500HD 4X4 crew cab - 45,000 miles, Duramax/Allison, Cognito 4-6 inch lift set at 4 inches, Cognito pitman arm/idler arm supports and HD drag link ends, BFG AT/KO 315/70R17E tires, Warn bumpers front and rear (no winches, but with provisions to mount them), Viair 2.5 gallon on-board air tank & compressor w/hose that reaches all 4 tires, Ride-Rite front air shocks w/in cab adjustment and monitoring of air pressure, 52 gallon fuel tank, and IPod ready stereo.
And a 2000 FWC Hawk - 3 way refrigerator, 100 watt solar panel and MPPT charge controller capable of handling 400 watts worth of panels, 2 sealed, lead-acid batteries rated at a total of 200AH, a total of 32 gallons of fresh water storage in 2 separate tanks (with an electric pump to move water from the secondary tank to the primary), lockable storage under the sofa (which converts to a 40" wide bed), a 30" wide, over the cab bed, right side awning, custom fold down table on rear, left side, outside wall.
$10,000 for the combination. The mechanical jacks are not mounted to the camper, but you have to take them too. You arrange transportation.
