Aftermarket Battery Monitor
#1
Posted 08 October 2010 - 10:51 PM
What do you use?
2003 Tundra TRD 4WD & a 2007 Palomino Bronco 800 to be driven down the PanAm during 2011.
Read about the Hardware Here.
#2
Posted 08 October 2010 - 11:33 PM
#3
Posted 09 October 2010 - 12:38 AM
What do you use?
Why not mount one of these voltmeters directly to the monitoring panel?
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
#4
Posted 09 October 2010 - 01:31 AM
Looks great, where'd you pick that up and how accurate is it?
#5
Posted 09 October 2010 - 01:58 AM
Here is the original link by "b team" (half way down the page) that gave me the idea:
http://www.wanderthe...70/page__st__30
Here's a link for the meter. Note that this meter comes in two versions....one with a maximum of 24 volts and another with a maximum of 40 volts (same price). You may as well get the 40 volt version for a little protection against burning out during a voltage spike. That's the one I got and it works great. Very accurate...as it agrees exactly with my regular volt meter.
http://www.newark.co...eter/dp/28K2619
There is an issue with the monitoring panel when you view it from standing....the light bleeds through and gives a false reading unless you bend over and look directly at it. I came up with a fix. Small strips of velcro laced in between the lights to keep the glow directed at the correct window. Here is that link.
http://www.wanderthe...__fromsearch__1
#6
Posted 09 October 2010 - 03:21 PM
i mounted mine on the wood panel near the battery facing rear so i could see it while standing outside the camper.
i can start the truck engine and watch as the battery separator finally kicks in (there is a delay) and allows the engine to charge the house batt. it confirms the plug is connected and that we are good to go.
you can see the solar charge controller as is progresses through its charging sequence....over and over, as long as there is adequate light. having a meter helps you to get a feel for how much light really is requred.
and you can see when the 12v converter is active - brute force 13.5 (with no smart chg adapter)
#7
Posted 09 October 2010 - 05:48 PM
Someone else of the forum uses this meter: http://www.powerwerx...-dc-inline.html and that looked interesting as well.
I just haven't bothered to buy/install anything else yet since I toasted the lascar since a multimeter is working fine for me currently.
2007 Dodge 2500 quad cab 4x4 5.7L Hemi auto and slowly progressing build.
FYI: I've got a bunch of extra 14ga wire in red and black. Its a thick jacket 41strand wire (likely MTW wire) verse typical 19strand automotive wire. It has good flexibility but factor in the thick jacket. I'll ship out 100' coils for $18 (I can go 50' of ea for that too) if anyone is in need of wire.
#8
Posted 10 October 2010 - 11:05 PM
I'm lost, but I'm making good time. Beer is good food. Beer makes you feel the way you ought to feel without beer. Beer is the reason I get up every afternoon. Beer is living proof that God loves us and wants to see us happy. Beer is water that has reached it's full potential.
