POD: Homebuilt foam core fiberglass skin pop-up camper build thread
#181
Posted 02 July 2020 - 02:37 PM
#182
Posted 02 July 2020 - 03:21 PM
There ya go, not recommended. Hindsight 20-20, its in the past mov'n on and not recommended for others.
#183
Posted 03 July 2020 - 07:42 AM
Laminating directly to XPS or EPS directly is asking for delimitation. Normal construction with an EPS core is to bond a thin layer of high density foam, like Divinycell, to the EPS before the outside layers of fiberglass are laminated. This adds toughness to the composite panel. Also, most products that use EPS core also have vent plugs to keep them from delaminating due to heating/cooling.
I think everyone that followed this thread is curious how to do diy foam core fiberglass construction properly with the best value and least amount of labor. You seem knowledgeable. Do you mind sharing some good resources for learning more about it?
#184
Posted 03 July 2020 - 01:28 PM
With any of the from scratch methods the finishing takes a huge amount of time. Sanding, fairing, and painting can be frustrating. The Total Composites kits are pre-finished and would save a ton of time.
#185
Posted 03 July 2020 - 07:53 PM
Thanks. That FUSO on the Total Composites website is delux.
Balsa core and vacuum bag lamination sounds laborious and expensive. What intrigues me most about foam core fiberglass construction is the flexibility of shapes (aerodynamics, seamless corners, round shapes, etc), strength to weight ratio, and the insulation. Building the molds though is difficult and time consuming. I would love to find successful methods of using inexpensive foam that can be constructed first and then carved into smooth corners that become seamless after typical fiberglass application, requiring no molds. But I am dreaming. Delamination seems to be the single problem that prevents simple construction.
Total Composites is very intriguing. Thanks for sharing.
#186
Posted 04 July 2020 - 12:11 AM
#187
Posted 12 April 2022 - 02:44 AM
Just picked up this thread (2 years later). Thanks for posting this it was super interesting, and even though your camper didn't work out there was still a lot of great ideas along the way. Engineering is just as much about design failure as it is success and documenting the way *not* to go (and why) also saves others a lot of trouble. Cheers
