Sure Power 1314 Recall - FYI
#11
Posted 14 July 2011 - 05:41 PM
Cort
#12
Posted 14 July 2011 - 05:57 PM
If the manufacturer has deemed there is enough of a problem to warrant a recall, it will have a timeline of immediately (i.e. NOW!). They can't very well advise you to keep using it until it is convenient for you to replace it. If your camper burns down before you got around to replacing it because they said take your time, even though it is a known hazard, that exposes them legally.
You have to make your own judgement to the risk/reward ratio choosing to continue to use it. So you can replace it now with soemthing else or choose to wait.
I bypassed mine in favor of a truck mounted automatic charging relay unit.
You could wait to replace it when stock is available this fall and unplug your cable to the truck bed power receptacle, then it will be turned off and present no problems when you are not looking. Plug it in temporarily when you need it and can monitor it for your peace of mind.
I agree not looking for any dangerous problems.Explain the automatic charging unit please,where to get one and what they are.
Thanks Frank
#13
Posted 14 July 2011 - 11:55 PM
It will charge all the time - which will be better than not charging.
#14
Posted 15 July 2011 - 12:19 PM
I'm going to just run without the separator for the rest of the summer and straight wire the truck charge line to the camper battery. I'm really not at risk of draining my truck batteries in the summer now that it is finally warm enough to not need the heater.
Possible downside is the camper battery will be connected when you start your engine. That means a big load transient, more concern is the current draw temporarily attempted down your camper wire and connector. Not likely a problem for most people, but something to consider. Smaller wire has higher voltage drop, so will naturally self limit the current as long as the starting battery can supply the need. If you have a weak starting battery, your camper battery may try to supply the missing current and stress your wiring or connector. If you have not properly fused the the camper wiring to protect the weakest link (possibly your connector of choice, not always the wire size, or a crusty connection) you might melt the wire insulation and cause a short or at the extreme a fire.
- Mike
2016 F-150 FX4 XLT SCab | Ingot Silver | 6.5' | 3.5EB | 3.55 w/rear locker | Tow | IBC | 7050# GVWR | 1945# Payload | 36Gal | BFG A/T KO2 LT275/70R18E | Timbrens
2022 FWC Hawk Silver Spur | Front Dinette | Cassette Toilet | Cooktop | Hot Water | Outside shower | CR850 fridge | 160W rooftop solar panel | 15A MPPT controller | Dual 90AH AGM batteries | Yakima Rack | 2 Maxxair fans | Furnace | Fiama side awning | Mechanical Jacks
#15
Posted 15 July 2011 - 12:39 PM
Thanks Frank
Automatic Charging Relay (ACR), Battery Combiner, Voltage Sensitive Relay (VSR)
These are really the same things, different name. A solenoid, relay, or solid state switch that has circuitry to monitor the startng battery side voltage (or both sides in some models) and when the voltage rises above a setpoint like 13.4VDC, will close the switch and parallel both batteries.
The idea is the starting battery must be reasonably charged by that time (high enough voltage achieved) and so it is OK to connect the house battery and start sharing charge voltage with it.
When the engine is turned off, the charging stops, the voltage on the system will drop below a setpoint such as 12.8VDC and the switch will open separating the 2 batteries. Now a camper load will not drain your starting battery or reverse.
Diode isolator types have no switching, but introduce more voltage drop permanently into the system, limiting your max charge voltage at your battery. They must also dissipate heat through a large finned housing.
Marine units are explosion proof and corrosion protected by being packaged into an enclosure whcih adds cost. The Surepower unit is open frame with a minimal cover and thus is lower cost. Same operation though.
I use a Blue Sea System marine unit that has built in current limiting to 60amps for the camper side wiring for extra protection and is a solid state switch with low voltage drop. My preference for my application, same results. This just illustrates that you can find a solution in the marine stores as well as 4x4 and RV outlets.
There are several marine and 4x4 offroad units on the market. Most on the store shelves are rated for 100-200 Amps, with bigger ones for 350amps or more using larger solenoids such as for the 24VDC banked battery systems on large craft. A 100amp unit is quite fine for our application.
Some sample marine unit limks
http://bluesea.com/category/2/productline/overview/387
http://www.marine-electronics-unlimited.com/Blue+Sea+7600+CL-Series+BatteryLink+ACR+s.html
http://www.hellroaring.com/battery1.php (this is a popular offroad/RV brand)
This one is educational and happens to use the Model 7600 CL BatteryLink version unit I use:
http://bluesea.com/viewresource/59
3 versions compared:
http://www.jamestowndistributors.com/userportal/document.do?docId=142&title=Three+ACRs+from+Blue+Sea+Systems
#16
Posted 15 July 2011 - 02:29 PM
- Mike
I did consider it but I am using the factory 12V+ wire to the factory 7-way RV trailer plug from Chevy which is hot 100% of the time. If it was at all risky I'd be a member of a class action lawsuit by now The 12V+ is fused at the truck at the factory power distribution center.
I should test it when starting to see if I get any sizeable reverse flow though.
I have seen a truck melt wires, when trying to charge a deed battery after being jump started, so I know what you are talking about.
#17
Posted 15 July 2011 - 07:54 PM
Having said all this I just ordered the 1314-200 from ASE Supply Outlet. The cost is $111.00 including shipping.Bought done.
When it arrives I will remove the 1314 model and return it to Sure Power for a full refund.
If anyone is in this same position you need to contact Judy @ Sure Power for the UPS return label.
I went this route because I wanted to have the same simple connection that I now have.Didn't want to fuss with different wiring and such.
I want to thank ugulyscout for bringing this issue to us.I am sure there are other WTW members that this affects and hope all this will help.
Camp safe contact smith auto smithae.com or 509 453 8275 ask for Jim
#18
Posted 16 July 2011 - 04:51 PM
Is Smith Auto the same as ASE? Guess it doesn't matter, but if Jim was helpful might as well send business his way.
Thanks for your help.
#19
Posted 17 July 2011 - 03:33 AM
Good advice here, and thanks for bringing it to everyones attention.
#20
Posted 18 July 2011 - 10:55 PM
Michael
I'm lost, but I'm making good time. Beer is good food. Beer makes you feel the way you ought to feel without beer. Beer is the reason I get up every afternoon. Beer is living proof that God loves us and wants to see us happy. Beer is water that has reached it's full potential.
