Wiring question
#11
Posted 31 July 2007 - 03:20 AM
Alternatively you could temporarily install a manual switch in its place until you can get the battery seperator. That way you could at least charge the camper. Just don't forget to turn the switch off when you stop to camp.
~Jim2000 Tundra AC- 2000 FWC Ranger
2017 Tundra DC - 2017 ATC Panther
#12
Posted 31 July 2007 - 03:15 PM
That was my thought as well I have a 30A inline fuse and figured it would do the trick.
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#13
Posted 01 August 2007 - 11:24 PM
Come to think of it, the fuse is also thermal Breakers, at $5-6, are less expensive in the long run than ATC/ATO fuses; personally, I don't like the in-line glass fuse holders because they tend to have corrosion problems, esp around batteries...
http://www.crowbarel...Fuseholders.htm
#14
Posted 01 August 2007 - 11:34 PM
Breakers are less expensive in the long run than ATC fuses if you buy the fuses in onesy-twosy; personally, I don't like the in-line glass fuse holders because they tend to have corrosion problems, esp around batteries and prefer the covered ATC holders.
#15
Posted 02 August 2007 - 04:47 PM
When it comes to airplane systems and my electrical system I say you cant have too much redundancy. I've got everything fused all over the place just in case I did something wrong. Which for me is a daly occurance.
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#16
Posted 02 August 2007 - 09:07 PM
Actually, what I have done on my wiring systems is an auto-reset circuit breaker at the truck battery and another at the house battery, with no fuses in the system -- I don't want to find the fuse was blown by discovering a dead battery when I expected a live one. I got the idea from the trailer brake control specifying an ARCB for the brake wire (apparently so one doesn't have to climb out on the hood to change a fuse whilst rocketing down a mountain pass...)
#17
Posted 02 August 2007 - 10:03 PM
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#18
Posted 03 August 2007 - 09:16 PM
Hmm, I wish I'd known there are "boots" available for them; I tie-wrapped some split cable loom over mine in case someone clumsy dropped a tool on them...
I made up a short wire between a copper lug on one screw of my battery terminal (my Ranger is Mazda-based, so it uses the steel battery clamps, not lead ones) and put crimp ring terminals on the ARCB.
BTW, if you are using crimp terminals, do NOT tin/solder the wire ends before crimping -- The solder may 'cold creep' over time and pressure and the connection will loosen.
#19
Posted 04 August 2007 - 03:08 PM
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
#20
Posted 05 August 2007 - 05:59 PM
