buy a half-ton with the correct gearing and you can actually enjoy driving your truck.
I enjoy driving my 3/4 ton WAY more than driving my 1/2 ton.....even around town.
Posted 02 December 2011 - 06:30 PM
2010 Ford F250 4X4; 6.4 Powerstroke Diesel; Warn 16.5 winch; Airlift Springs; Transfer Flow 47 gal. fuel tank, BDS 4" lift kit, BDS dual steering stabilizer with upgraded Fox 2.0 shocks, Toyo 35X12.50X18 Open Country M/T tires, Pro Comp wheels; 2008 FWC Hawk Camper; 2000 Toyota Tundra.
Posted 02 December 2011 - 06:39 PM
Posted 02 December 2011 - 07:25 PM
JayAronowSales.com
(520)579-9610
jayaronow@gmail.com
Posted 03 December 2011 - 03:14 AM
Posted 03 December 2011 - 07:41 AM
Yeah, I can't imagine driving your 12 year old underpowered toyota is much fun. I was talking about driving a newer F150, they ride as nice as most cars.
Posted 03 December 2011 - 03:12 PM
My Toyota is not under powered at all as long as you don't drop a 1500 lb. camper on it's back. Around town it drives just fine....very car like too.
The point I was trying to make was not comparing my old 1/2 ton to your new 1/2 ton....but that the 3/4 ton trucks are not bad at all to drive around town. Not nearly as clunky as in the old days.
Safety wise it's a no brainer. I don't care what make or model year you are talking about. If you compare the same make and model for any given year, 1/2 ton vs 3/4 ton......and you load that truck up with a Hawk camper.....the 3/4 ton will always handle the weight better and stop better than the 1/2 ton with the same camper. Its simple....bigger brakes means less stopping distance. I hope you are never in a situation where that difference matters....I've been there....and I wouldn't wish that on anyone.
Posted 03 December 2011 - 03:36 PM
I have pored over the specs on Fords pdf's and unless I am not understanding brake techinal speak I see very little differences. In fact, the 2012 F150 now has a slide in camper approved package that has a pretty large payload - an increase of well over 400 pounds comparing the same trucks side by side. No brake enhancements. Also, if you look at the 2012 F250 and a 2012 F150 I am probably not understanding what I am reading - but I don't see anything that says "bigger brakes". If someone cares to look and can explain it in layman's terms using the actual specs I would be grateful.
FWIW my 2011 F150 with max trailer tow package in the 6.5 bed supercrew has an available payload according to the door of 1690 lbs. My Hawk shell data sticker says it weighs 585 lbs with propane (I have the furnace). After my wife and I and two dogs are in the truck we still have over 700 pounds of payload capacity to spare. We did add airbags and E rated BFG AT's and are mindful that we have a load. With perhaps 20% of the lifetime miles of the truck cooming with the FWC in the bed, the fact that it all mathematically adds up according to the truck and FWC's data, then applying basic 80/20 principles to the decision - voila' I bought an F150. I did trade in a fairly new Tacoma due to the numbers not adding up for me personally when it came to payload and camper weight, but there are sure alot of guys running that combo that seem very pleased.
Really curious about the brakes thing if someone could take a stab at that using actual specs and explaining what it means.
Posted 03 December 2011 - 03:45 PM
Posted 03 December 2011 - 09:28 PM
The brakes guys is trying to compare his undersized half ton (2000 tundra) to his over-sized f250. Apparently he has not looked at half-tons since 2000 since he thinks a f150 does not have the brakes to haul a 1500 pound camper. Yes an f250 will haul it better and more safely, but a f550 would will haul it more safely, so maybe you need one of those instead. Yes a 2000 tundra is an undersized half ton with a cheap interior and lots of road noise, I would not make it my daily driver either or trust it to haul a 1500 pound camper. The brakes guy needs to go drive a new tundra or f150 and then come back and tell us how nice his f250 rides in comparison.
Will, 2019 Ford F150 with a 2022 Hawk
Posted 03 December 2011 - 10:50 PM
