Gray Water tank for Hawk
#11
Posted 15 March 2012 - 04:00 PM
Keith Barnes El Cajon CA 2021 Ram 3500 Diesel with 2016 Lance 650
#13
Posted 02 May 2012 - 11:26 PM
First try. Tank fit by the elbow stuck out 1/2" too far
Second try had to lower tank so it was lower than the wheel cut out. Tanks holds 3 gallons enough for a stop or two.
I made the tank out of 4" PVC put caps on the end. Had to move the fill when I lowered the tank. All holes were drilled and tapped, I put epoxy on the threads and tighten then down.
Sink stays attachecd to tank. Note how close to the camper the pvc had to be on the Tundra.
See next post can only get 4 pictures on this post.
Bill Harr 2005 Tundra and a 2013 Hawk custom interior.
#14
Posted 02 May 2012 - 11:31 PM
How close to the bed the fill needed to be
Vent hose
Going to give it a try next week gong to Port Townsend WA.
Edit if I did this again I would attach the tank to the camper under the wheel cut out, there would be room on the Tundra. Would run the fill to the tank under the sink with a 3 way valve so you would not have a hose attached all the time. 3 way valve would allow you to still use the out side drain. Drain from tank would need to be run out the back of the camper behind the heater, this would take more work.
#15
Posted 02 May 2012 - 11:35 PM
#16
Posted 02 May 2012 - 11:44 PM
#17
Posted 03 May 2012 - 02:19 AM
"Not all who wander are lost. Except Ted, he's usually lost." Dirty Dog
#18
Posted 28 May 2012 - 03:31 AM
Bob
2007 Dodge 2500 5.9 CTD QC 4X4, *1996 FWC/ATC hybrid* *2021.5 GeoPro 19FBS* "If you can read this, Thank a Teacher. Because you read this in English, Thank a Vet."
#19
Posted 13 September 2012 - 08:36 PM
#20
Posted 10 December 2012 - 10:04 PM
