Installed the ho-made slide for the Engle45 and the corner countertop.
New ATC Ocelot Shell Buildout
#31
Posted 13 June 2014 - 03:56 PM
#32
Posted 13 June 2014 - 04:00 PM
Going fast and looking good.
Bill Harr 2005 Tundra and a 2013 Hawk custom interior.
#33
Posted 13 June 2014 - 04:14 PM
Thanks Bill I "completed" the interior about a month ago but didn't have time to post. Trying to do a Readers Digest version here for I have a great need to get out of town. It's that time of year to be dry roasted down here in Tucson.
#36
Posted 13 June 2014 - 05:00 PM
The slide pulls out far enough to be able to plug the 12v cord to receptacle. Custom turnbuckles( turnbuckle and threaded rod cut to length and bending end into a hook) hold the Engle to the slide. There is just enough room to slide the stove between refer and front wall. I have used this type of slide for five years in the Landcruiser and never had a problem. But this system only works if you have a surface to pull the slide unto.
#37
Posted 13 June 2014 - 07:01 PM
At this stage of the build I got lazy with the picture taking, so will take you to the "finished product." I do not have an electronic water tank gauge. I left the area under the refer open for easier access storage and can visually see exactly how much water is in the tank.
Edited by Ambling1, 13 June 2014 - 07:02 PM.
#39
Posted 13 June 2014 - 07:38 PM
When I ordered the camper I deleted the overcab mattress. I wanted to try a 3" thick bed to have more room for bedding. Tried a trifold mattress from Costco that was 36" wide but it was terrible. It was made out of batting and not foam. This pictured trifold mat is foam and even though it is not well tested, I have high hopes for it. Purchased through amazom, can't find the info on it right now but search under futon. Size is 27"x 75" and came in several colors. Will definitely be my stealth mattress.
