Very cool build on your shell. You are talented and I like the way you set it up. More ideas to ponder:)
New ATC Ocelot Shell Buildout
#71
Posted 27 January 2015 - 02:49 AM
2018 Ford F-250. Customized Bundutec Sable
#72
Posted 28 February 2015 - 05:48 AM
Texan, At this stage I have two screws holding the face frame to the rear wall up by countertop level to keep it plumb. The top 1x2 framing at countertop level is just floating at this stage. The 1/2" plywood is screwed to the floor pack. If I take out the screws from the plywood and those two other screws, I can lift this section out as a unit. The vertical section of plywood is off the side wall by an 1/8".
Was this done so you can do some of the detailed work outside of the camper and attached the unit to the wall at a later date? Or did you leave 1/8'' room to account for flex?
2003 Tacoma 4X4 - 2007 FWC Eagle shell
2006 Tundra Double Cab - 2015 Hawk - side dinette, silver spur interior
#73
Posted 11 September 2015 - 03:10 AM
Can you please give details on how you sealed the propane locker on the inside? I, too, would like interior access but I want it to be airtight. I'm just not sure of what I can use for a seal on the interior access door. Thanks.
#74
Posted 10 April 2016 - 12:30 AM
Awesome build, thanks for posting all the photos!
#75
Posted 27 April 2016 - 08:05 AM
Thanks for showing us the potential. It was great to see the whole thing completed. Very good progress.
Have you got a final dry weight? What was your final cost. You can describe it as percentage savings versus dollar amount. I know you put a lot of labor hours into it. You did a fantastic job!
#76
Posted 17 September 2020 - 06:38 PM
More detail of dinette seat.
Naive question here, what are the handles under the dinette seating for?
