04 Eagle battery and water monitor
crystalized
Nov 30, 2024
Posts
17
bishop
When replacing my electric water pump shurflo. The monitor that shows battery level and water level and pump switch apparatus went dead (no power). This is a 2004 Eagle. Anyone know how this monitor is connected to the electrical system? Thanks!
Those wires are easily accessed from the cabinet door below drawer. There should be a partition that separates this space which is easily removed by two screws in L brackets. You will see the wires connected to the unit and can use a tester to see if juice is getting to the unit. The wires go along (in my 2011 Eagle) the cabinet face to the fuse box. Certainly check fuses first!
Great thank you! Will check the these and the fuse box.
