10lb propane tanks for Fleet shell
Bread
Nov 19, 2013
54
Just picked up my new Fleet Shell from Sean at Go Anywhere!! Woohoo! Now I'm busy tricking it out. Ordered the shell with a propane tank cabinet big enough for two 10 lb tanks.
Looking at tanks online and Home Depot has Worthington Pro Grade 11lb tanks for $56.97 which seems like a good deal compared to other stores. Will 11lb tanks fit? Have never used tanks this size and not sure if there is a big difference in size between 10 and 11lb tanks.
Here's a comparison of 10# and 11# DOT approved propane tanks. Capacity is simlar but looks like the difference is height and diameter. 17.4"x8.9" versus 12.4"x12.2", respectively. The 11# tank is shorter and with a larger diameter. Two11# tanks won't fit in my cabinet.
10228.4 10# DOT Vertical ACME/OPD Cylinder 10 2.4 23.8 17.4 8.9 15
10393.1 11# DOT Vertical ACME/OPD Cylinder 11 2.6 26.1 12.4 12.2 14
I read your post a day late and $36.00 short (shipping) having just ordered the Manchester 10# tank. :cautious:
The Manchester 11# tank is a rather squat shape like JHa6av8r said, however the Worthington 11# tank is 16.8 x 9.1. With free shipping from Home Depot Online the Worthington 11# is a good deal. The interior dimensions of the FWC plastic propane box in my Fleet is 19.5"h x 11.5"w x 17.5"d .
Cheers
A more crucial dimension is the actual width of the opening at the propane door. That number is 10-3/4"
Good point ! I mounted mine on the side of the Fleet and the door only opens to 10-1/2" do to the jack.
Cheers
