HD3017
For sale is my 1982 Four wheel camper Grandby. I have done extensive work to this camper both to repair it and to modernize it. I am willing to deliver it within a 20hr drive of Denver. Feel free to reach out if you have any questions. I would also be willing to negotiate on price if I keep some of the more valuable items such as the fridge or li batteries. I work at FWC dealer as a dealer technician, the work done to the camper has been done with care. I took this camper to Alaska and back summer 2024 and it was excellent. A pair of brophy jacks will be included in the sale. This camper only fits trucks with a 64in tailgate opening. I am selling it to purchase a Hawk and would be willing to trade for one.
Camper Repairs
-New wood in the bed overhang
-Roof trim resealed with 3M 4200 and new screws with neoprene washers
-Door completely rebuilt with new wood, panels and handle
-Floor replaced with vinyl floors
-Butyl replaced behind the windows and exterior trim
-Both bi-fold panels replaced, the front is a good used factory unit, the rear is a new one made from 1/4 marine ply
-The Original Atwood heater has been cleaned and has a new fan motor, works excellent.
-New sink drain
-All slides repaired and in working order
Camper Upgrades
-Updated to use turnbuckles
-New LED porch light
-Bed converted to a pull out, similar to the new FWCs, allows for a larger mattress (mattress is less than 1y/o memory foam)
-Sink upgraded to a stainless bar sink and is much deeper
-Set up for Starlink 3 including a mount for the router, 12v conversion and outdoor RJ45 port in the propane locker to connect the dish
-Lagune style mount for the factory table
-New blackout curtains
-Hatch added to access the driver rear turnbuckle, allows for additional storage
-Anderson flush mount connector for power input from truck
-Dometic 12v Refridgerator with freezer
-New copper propane lines
-Maxair Fan
-110a plugs added to the kitchen and under the rollover couch
-12v USB plugs added to the kitchen and bed areas
Power System
-2x 100w Renogy Solar panels
-Victron MPPT solar charge controller
-Victron 30a DC to DC charge controller
-Victron Smart Shunt
-3x LiTime 100ah mini lithium ion batteries
-12v automotive-style fuse box and all new wiring to all systems with deutsch connectors for servicing
-Everything is either fused or on a breaker to allow for servicing, all appropriate wire gauge was used
-Renogy 2000w inverter
Water System
-20gal water tank in front bench
-Surflow 12v water pump
-Camplux on-demand propane hot water heater hard mounted and vented
-New sink faucet for hot and cold water
-External shower with hot and cold water
-Pex tubing with shut off valves for the water tank, hot water heater, shower and faucet
Things that need attention
-The canvas is stiff and cracking at the front, under heavy rain it get damp
-The headliner has some tears in it and could be replaced
-The wood trim on the headliner could be replaced
Camper Repairs
-New sink drain
Camper Upgrades
-Maxair Fan
Power System
Water System
